Nusselt Number calculation in Ansys CFX
Like Tree5Likes
Old   April 24, 2013, 19:18
Marco Correa
marcoac14 is on a distinguished road
Originally Posted by siavash_y View Post
I have the same problem, did u find a solution marcoac?
Well, not a good one. I found workarounds, not real solutions.
As many users suggested, you can use design modeler to imprint planes along the channel and interpolate them. If you're working with parameters this is the best solution in my opinion because you can write an expression to give you the result right away. It will give you a fairly good idea of what's happening, but may not be as accurate as required.
Another solution is to export temperature and velocity as a csv file and use it in Mathematica (or similar) to interpolate over the domain and extract the results you need.
Regards,
Marco
marcoac14 is offline   Reply With Quote
Old   February 24, 2015, 12:35
VIPIN KAKKAR
VIPIN KAKKAR is on a distinguished road
i am simulating natural convection heat transfer from perforated fin array and have solved the problem in CFX,but i am unable to find out Nusselt number of the fin array.
please tell me how to find out Nusselt number of fin array.
VIPIN KAKKAR is offline   Reply With Quote
Old   February 24, 2015, 12:49
VIPIN KAKKAR
i am working on natural convection heat transfer of perforated fin array in CFX. i have solved it in CFX, now i need to find out Nusselt no. of fin array for that first of all i have to find out heat flux value of fin. The problem is with the post processing software as I don't really know it well enough. How do I extract the heat flux values for my FIN wall?
Old   February 25, 2015, 11:23
Edmund Singer P.E.
singer1812 is on a distinguished road
Use variable "Wall Heat Flux". This of course assumes you didnt model the wall as adiabatic......
singer1812 is offline   Reply With Quote
Old   February 27, 2015, 22:42
VIPIN KAKKAR
sir,
may you explain me how to use "wall heat flux" variable. when i select wall heat flux in variable tab it shows value of min & max heat flux, whether this min & max value is for whole body?
i want to find out Average heat flux for a single body & single surface. Please tell me how to find out.
Old   February 28, 2015, 07:29
The min and max refer to the object locator it is referring to.
Use the function calculator to calculate any function of any area.
Old   March 1, 2015, 09:17
VIPIN KAKKAR
sir,
i am finding heat flux using two expressions- areaAve(wall heat flux)@location and ave(wall heat flux)@location.
value for both the expressions is different.
what does function areaAve and ave mean?
Old   March 1, 2015, 18:18
This is explained int he documentation, in the CFX reference guide. areaAve is the area weighted average and ave is just a simple arithmetic average.
Old   March 2, 2015, 00:41
VIPIN KAKKAR
Thank you sir for your suggestion!
sir,please tell me one more thing what does areaAve(Temperature)@location
" area weighted average temperature" mean. Is it absolute temperature or relative temperature(difference of absolute and atmospheric temperature).
In my fin array problem when i gave heat flux 5900 W/m2 to fin base then areaAve(Temperature)fin shows 140 K.
Old   March 2, 2015, 00:57
The temperature returned will be the temperature variable - that will be defined as C, F or K depending on your setup. And it is an absolute value, not a relative one.
If you have and areaAve(temperature) of 140K then your fin is really cold. This is 140K absolute, so 133K below the freezing point of water. I hope this is what you intended to do.
Old   March 3, 2015, 07:43
VIPIN KAKKAR
Thank you sir!
sir, in my problem of "natural convection heat transfer from perforated fin array", i can calculate heat flux and temperature at any face of fin array in CFX-post ,but how to calculate Nusselt Number of Fin Array in CFX-post
Old   April 2, 2015, 10:58
VIPIN KAKKAR
sir please tell me how to find wall heat transfer coefficient and wall adjacent temperature. what are expressions to find these variables.
Old   April 2, 2015, 11:24
Thomas MADELEINE
Thomas MADELEINE is on a distinguished road
I don't understand your question...
you have the name of the variable so you can plot it in CFD-Post...
both of them are Wall variable so plot it on the Wall with a contour.
For better understanding use the CFD-Post Help on these variable and the CEL function...
Thomas MADELEINE is offline   Reply With Quote
Old   December 1, 2016, 23:23
Pyotr is on a distinguished road
Hi everyone,
I’ve been running a simulation of gas flowing through a multi hole heated solid body. I need to obtain data like Reynolds, Prandtl and Nusselt number along the channel.
In order to obtain data from various cross-sections along the channel, I’ve created a surface (Insert -> Location -> User Surface), Method -> Offset From Surface, which is parallel to the outlet surface. I just change the distance from the outlet and I get all the data in the new location. All the expressions contain a reference to this location.
I called the user surface “Data Collection” and the expressions are as follows:
ReDataCollection (Reynolds number):
sqrt(4*area()@Data Collection/pi)*areaAve(Velocity)@Data Collection*areaAve(Density)@Data Collection /areaAve(Dynamic Viscosity)@Data Collection
PrDataCollection (Prandtl Number):
areaAve(Specific Heat Capacity at Constant Pressure)@ Data Collection*areaAve(Dynamic Viscosity)@ Data Collection / areaAve(Thermal Conductivity)@Data Collection
TwallDataCollection (Temperature at the wall):
areaAve(Wall Adjacent Temperature)@Data Collection+(areaAve(Wall Heat Flux)@Data Collection/areaAve(Wall Heat Transfer Coefficient)@Data Collection)
TbulkDataCollection (Bulk Temperature):
areaAve(Temperature)@Data Collection
MyHTCDataCollection:
areaAve(Wall Heat Flux)@Data Collection/(TwallDataCollection- TbulkDataCollection)
NuDataCollection (Nusselt Number):
MyHTCDataCollection* sqrt(4*area()@Data Collection/pi)/ areaAve(Thermal Conductivity)@Data Collection
I got the diameter of the channel from sqrt(4*area()@Data Collection/pi), since the calculated area is not exactly what I expected from theory (just a minor difference), but to maintain the consistency, I chose to evaluate like this.
I managed to get results that seem to be reasonable, but I am still uncertain about the accuracy of expressions I used to obtain Nusselt Number.
Is it correct to use “areaAve(Wall Heat Flux)@Data Collection”, “areaAve(Wall Adjacent Temperature)@Data Collection”, and “areaAve(Wall Heat Transfer Coefficient)@Data Collection” in this context?
“areaAve(Wall Heat Flux)@Data Collection”, for example, gives me the heat flux in the specific cross-section I am working on?
Thanks!
Pyotr is offline   Reply With Quote
Old   December 2, 2016, 04:02
Antanas is on a distinguished road
It seems to me that Wall Heat Flux is defined on wall, but not on cross-section.
Also keep in mind that locator based CEL functions use conservative values in calculations i.e. average over near wall control volume, but not boundary values.
Antanas is offline   Reply With Quote
Old   December 2, 2016, 05:40
As Antanas states, wall heat flux is not defined on a flow cross section plane.
You will have to define a curve at the intersection of your plane "Data Collection" and the wall. You can do this by a polyline with the "Boundary Intersection" option. Then you can do lengthAve(Wall Heat Flux)@Line on the curve to get the average Wall heat flux at that countour.
Old   December 3, 2016, 20:29
Hi Antanas and Glenn,
I did what you suggested, and the data I extracted from the polyline are about 1.5% higher, on average, than the ones I got from areaAve(Wall Heat Flux) at the cross-section.
Thanks a lot!
Specify number of cores that CFX should use. Lance CFX 16 July 20, 2016 10:04
DecomposePar unequal number of shared faces maka OpenFOAM Pre-Processing 6 August 12, 2010 10:01
CFX doesn't continue calculation... mactech001 CFX 6 November 15, 2009 22:25
Unaligned accesses on IA64 andre OpenFOAM 5 June 23, 2008 11:37
Nusselt Number of the order of 35000 chinmay FLUENT 4 May 31, 2001 04:06
