How to suppress convection & viscous effects using CFX
Old   January 17, 2011, 21:40
Default How to suppress convection & viscous effects using CFX
Hareesh R Iyer
Haga is on a distinguished road
In a free surface transient flow problem of a fluid in a partially filled container, how can one reduce or suppress the effect of convection & viscosity theoretically & using CFX?? Is it possible to achieve this simultaneously or would there be a need of compromising anything to achieve this condition?
Haga is offline   Reply With Quote
Old   January 18, 2011, 19:18
You cannot model inviscid flows in CFX, but you can specify a viscosity so low that it is effectively zero. This is easy, but may cause convergence problems especially for free surface problems.
CFX is a Navier Stokes solver so solution of convection is inherent. I cannot see how a free surface simulation could be driven by diffusion only. Can you explain why you want to stop convection?
Old   January 31, 2011, 21:09
Default @ Glenn
Hareesh R Iyer
1st of all...Thanks for replying...
Viscous effects as u said can be controlled so. But what is the use of convective term in a free surface problem of a liquid inside a container? If it was flowing, then convective effects can be considered. Since there's no liquid motion other than oscillation why it is that the convective effect be kept considered while doing the model?
Old   February 1, 2011, 18:31
If the fluid is moving then convective effects are contributing. If the fluid is not moving then forget CFD and it work out by far simpler methods.
So what are you trying to do?
convection, free surface, suppress, viscous
Pros and Cons for CFX, CFdesign, COMSOL Val Main CFD Forum 3 June 10, 2011 03:20
ATTENTION! Reliability problems in CFX 5.7 Joseph CFX 14 April 20, 2010 16:45
viscous effects in hypersonic flow (at high Re no) VVJ Main CFD Forum 1 November 20, 2007 09:35
CFX 4.4 installation problem Pandu Sattvika CFX 1 December 1, 2001 05:07
How to obtain correct viscous pressure drag using CFX? Ketut Utama Main CFD Forum 1 January 25, 1999 06:05
