January 16, 2011, 15:30 |
Modelling turbulator tape on airfoil
Dear All,
I am going to evaluate the effect and position of "Turbulator-tape" on an FX67-K170 aifoil(this is a tipical glider airfoil, used late 70s on many gliders, like LS3, Nimbus, LAK, Glassfugel, etc..). The main reason attaching Turbulator-tapes on airfoils to prevent flow separation, controlling the boundary layer. Is is commonly used on modern glider aifoils, but it was unknown at that time when the FX67-K150 and K170 aifoils were designed. The are two types: "Zig-Zag or 3D" with 0.5-0.8 mm height and "Dimple", which is a simple tape with small, about 1mm height bumps. You can see here: http://www.streifly.de/shop%20baender-e.htm how the zig-zag tape looks like. I am attaching two picturs for better understanding.I could use Ansys13. Thanks in advance any info, help. |
January 16, 2011, 18:14 |
Rep Power: 144 |
I am well aware of turbulators. But what are you trying to do? Assess the lift/drag on the airfoil with the turbulators in different positions around the wing? This will be tricky to model as correctly modelling the turbulators will be difficult to get accurate. There are a number of approaches (listed in approximately easiest but least accurate to hardest and most accurate):
1) Use a turbulance transition model and fix the turbulence transition point to the turbulator. 2) Use a turbulence transition model and use a rough surface at the turbulator to maybe trigger turbulence. 3) Use a turbulence transition model and use a source term to add the correct amount of turbulence intermittency at the turbulator to maybe trigger turbulence. 4) Do a full DNS model, including the turbulator roughness. |
January 17, 2011, 03:43 |
Thanks Glenn for your answer. Yes I am going to assess the lift/drag on the airfoil with the turbulators in different positions, because I have a glider with that airfoil. What does it mean "full DNS model"?
January 17, 2011, 17:43 |
Rep Power: 144 |
This will be difficult to model accurately, you are going to need some very good experimental data to get the turbulence triggering happening correctly.
Try google for a definition of DNS. I don't want to scare you |
airfoil trailing edge modelling in gambit | morteza08 | Main CFD Forum | 3 | June 4, 2010 14:36 |
Airfoil Ice Accretion Modelling Using Fluent | Virk | FLUENT | 0 | July 27, 2009 07:48 |
Modelling flow separation over airfoil at stall | Kelvin | Main CFD Forum | 4 | June 6, 2007 18:54 |
Modelling flow over airfoil at near stall angle | Kelvin | FLUENT | 5 | June 6, 2007 03:00 |
modelling an airfoil | Chetan Kadakia | FLUENT | 10 | December 3, 2001 17:17 |
