Heat Transfer convergence Problem mit a 1/6 compressor model
Old   January 14, 2011, 05:38
Default Heat Transfer convergence Problem mit a 1/6 compressor model
AB
chili023 is on a distinguished road
He guys
I am simulating a 1/6 model of a compressor at different rpms and with different geometry on an unstructured net with 8 prismlayers.
My momentum and Mass residuals look great as well as the turbulence residuals. But my heat transfer does not reach convergence, espacially when i apply a geometrical change to the model. The original model (no geometrical change) reaches convergence after 120 iterations.
I am simulating just the fluid with the following setups
inlet run static
compressor wheel rotating
outlet run
stationary simulation
Total Energy
SST
Adiabatic walls
Mass flow outlet
Air ideal Gas
Opening as Inlet
My main concern is the efficiency so the tmperatur is quit important.
Does anybody has an idea?
chili023 is offline   Reply With Quote
Old   January 15, 2011, 07:41
http://www.cfd-online.com/Wiki/Ansys...gence_criteria
inverse heat transfer problem siva0182 FLUENT 6 February 22, 2019 07:00
Heat transfer problem seojaho CFX 6 May 6, 2010 01:32
Wall heat transfer coefficient (HTC) problem Mohamed khamis CFX 1 January 16, 2010 00:12
regarding B.C. of Heat transfer problem Manoj Padmakarrao Raut Siemens 0 March 17, 2005 01:01
Heat transfer problem Brian CFX 0 September 13, 2004 02:19
