Different results from similar quality cfx and ICEM meshes |
January 14, 2011, 03:25 |
Nick
Rep Power: 16 |
Hi all,
I've created two meshes with the same geometry one in cfx and the other in ICEM. The mesh quality in both is nearly the same. However with the one from ICEM I get a floating point error whereas the one created in CFX converges nicely. I don't know what's the deal. Although I set the same Boundary Condition for both cases. Everthing else is exactly the same. Both are unstructured meshes by the way. Generally I get a lot of overflow (floating point) errors from ICEM meshes. Should the boundary conditions be defined in ICEM or is it sufficient to do so in cfx solver *which is what I do after i import from ICEM*. Thanks for any comments in advance. |
January 15, 2011, 07:34 |
Rep Power: 144 |
Assuming there is no error in your ICEM mesh, then your assessment that the mesh quality is almost the same is obviously not correct.
January 16, 2011, 05:03 |
Nick
Rep Power: 16 |
Thanks for the reply. Strangely I get this overflow error message with meshes from ICEM. I don't know what I'm doing wrong. The same geometry and boundary conditions for a mesh generated by cfx mesh work fine.
January 17, 2011, 08:48 |
Paulo Alexandre Costa Rocha
Rep Power: 17 |
In your simulation's .out file there are mesh quality statistics. Try to compare them. Best Regards, Paulo Rocha |
Import Mesh from ICEM CFD to CFX | Andre Almeida | CFX | 16 | April 19, 2016 04:42 |
CFX and ICEM CFD - structured meshes | realanony87 | CFX | 10 | May 15, 2009 06:17 |
ICEM and CFX report different number of elements | Chris Basciano | CFX | 0 | July 20, 2007 18:24 |
CFX mesh & ICEM | mike | CFX | 3 | April 27, 2006 16:27 |
ICEM 10 mesh scale foe CFX | Korsh Mik | CFX | 2 | October 7, 2005 10:07 |
