Help to create a CEL expression for Step function |
November 2, 2013, 04:25 |
step function
#21 |
may
Rep Power: 13 |
Hi Glenn
I sure appreciate your suggestion. This isn't something I can find in the library. I've looked at all relevant materials and have run many simulations. I need to get some ideas to ensure I'm on the right track. |
November 2, 2013, 23:03 |
#22 |
Rep Power: 144 |
An essential skill for any researcher is the ability to find out what other researchers have done in your field. You are not going to get very far without it. You really should do some research so you understand ways mixing can be measured to determine what is appropriate for your situation.
I do not know ways of measuring mixing because I do not need to in my field. I can guess a few ways, but it would be just a guess. If I needed to measure mixing I would be doing a literature search to find what the state of the art is. There is no point using a metric when you later find another one is much more appropriate. So do the research and get it right first time. |
November 3, 2013, 00:07 |
step function
#23 |
may
Rep Power: 13 |
Sure, thanks
January 8, 2018, 01:08 |
Step Function for Inlet Velocity
#24 |
Mujahid Badshah
Rep Power: 11 |
I want to run a transient simulation for 10 seconds with a time step of 0.1 seconds. I have a rectangular domain with water as the working fluid. I want to provide an inlet normal velocity of 12 m/s for only 1 second and then want it to become zero suddenly after 1 second.
Kindly some body help me to write a step function expression or any other CEL expression to achieve my inlet velocity condition. |
January 10, 2018, 15:49 |
#25 |
Rep Power: 144 |
Set the inlet velocity to
if(t<1[s],12[m s^-1],0[m s^-1]) CEL is very simple and is explained well in the documentation. Make sure you read the CFX reference guide on the CEL, and do the CFX tutorials. |
January 10, 2018, 23:41 |
#26 |
Mujahid Badshah
Rep Power: 11 |
Hi Glenn,
Thanks a lot for your reply and help. |
cylinder, step function |
OpenFOAM static build on Cray XT5 | asaijo | OpenFOAM Installation | 9 | April 6, 2011 12:21 |
CGNS lib and Fortran compiler | manaliac | Main CFD Forum | 2 | November 29, 2010 06:25 |
Problem with rhoSimpleFoam | matteo_gautero | OpenFOAM Running, Solving & CFD | 0 | February 28, 2008 06:51 |
Help to create a CEL Expression | Juan Maria Campos | CFX | 2 | December 3, 2007 07:52 |
Lift, Drag Vs time chart,calculations | Jamesd69climber | CFX | 8 | February 17, 2005 17:23 |
