Mesh inverse volume - wind tunnel
Old   January 11, 2011, 13:36
Default Mesh inverse volume - wind tunnel
roald is on a distinguished road
Hopefully someone can help. I am building a wind tunnel to test UAV engines as part of a project. I have created a version of it in soliworks and imported it into ansys workbench using the IGS format.
I am using CFX to simulate my models.
I need to mesh the volume of 'air' conatined within the wind tunnel. It is an open wind tunnel but I have placed caps on either end so i literally want to mesh the volume contained within. There are some complex shapes and turning veins inside etc which i obviously want to preserve also.
If anyone knows how to do this, it would be really really appreciated!
Many thanks!
roald is offline   Reply With Quote
Old   January 11, 2011, 17:45
Parasolid is a better format than igs, especially for complex surfaces.
Your description is a pretty typical simulation. Do the tutorials and things should be clearer. There are lots of pre-processing tutorials on the ANSYS Community website.
cfx 12.1, inverse volume, wind tunnel
[ICEM] Negative volume error in hybrid mesh siw ANSYS Meshing & Geometry 4 September 3, 2014 06:25
convergence problem when use pisoFoam, LES for wind tunnel case Forrest_Lei OpenFOAM 3 July 19, 2011 07:00
[blockMesh] BlockMesh FOAM warning gaottino OpenFOAM Meshing & Mesh Conversion 7 July 19, 2010 15:11
defining velocity profile in a wind tunnel model Erdem FLUENT 0 June 20, 2006 14:00
