January 8, 2011, 08:00 |
Line as function of one coordinate
Andrew High
Rep Power: 16 |
Hello I need to write expression of temperature at line as a function of coordinate y. Coordinates x and z are constant. I tried to look in help, but I had found no solution. One possibility is to export it as chart values, but it would be too complicated, because I need to work with other values in CFX post.
Thank you for answers |
January 12, 2011, 11:41 |
Bharath kumar
Rep Power: 17 |
hi handrew,
i don't know the solution exactly.but i have an idea of doing this.make an expression like A = Y (i.e CFX variable),and a function named B with 1D interpolation scheme(like y=0 m;t=100deg c and y=10 m ;t=1000 deg c) and another expression named C = A(B). It may work for your need. |
January 13, 2011, 00:55 |
Rep Power: 144 |
This is easy to do with a CEL expression function or 1D interpolation function. Just make the input variable y and the output variable temeprature.
January 15, 2011, 15:54 |
Andrew High
Rep Power: 16 |
That s what I want to do. But i don t know the right syntax. I suppose that I should use function probe, but I don t know how to use it with line ( with variable y). I didn t find the solution in help either.
January 16, 2011, 17:21 |
Rep Power: 144 |
In CFX-Pre, click the 1D interpolation function option. It will sort the syntax out for you.
Compile problem | ivanyao | OpenFOAM Running, Solving & CFD | 1 | October 12, 2012 09:31 |
1.7.x Environment Variables on Linux 10.04 | rasma | OpenFOAM Installation | 9 | July 30, 2010 04:43 |
Problem with compile the setParabolicInlet | ivanyao | OpenFOAM Running, Solving & CFD | 6 | September 5, 2008 20:50 |
[blockMesh] BlockMeshmergePatchPairs | hjasak | OpenFOAM Meshing & Mesh Conversion | 11 | August 15, 2008 07:36 |
OpenFoam 14 installation problem | gfcoppola | OpenFOAM Installation | 20 | November 2, 2007 13:38 |
