Evaluate bulk temperature as an expression
Old   January 4, 2011, 15:14
Default Evaluate bulk temperature as an expression
mullenc525 is on a distinguished road
I am evaluating heat transfer between different duct geometries. I want to be able to calculate HTC as h=q/(twall-tbulk). Then I want to take that htc and average it over an area.
I am having difficulty doing this symbolically, versus at a point. For example, to get bulk temp, I need to take an area average of temperature over a location, like ave(Temperature)@Plane 1. The problem is, I want the location to vary, instead of an xy plane at point z, I want z to vary. This way, I would get tbulk as a function of z.
Does anybody know how to do this?
I do not want to use expert parameters to set tbulk constant. This would cause h to decrease in the streamwise direction as the fluid heats, and would make it a pain for me to compare different geometry.
mullenc525 is offline   Reply With Quote
Old   January 4, 2011, 16:49
Edmund Singer P.E.
singer1812 is on a distinguished road
How many z's do you have? If not that many, just create new expressions at different z's.
If alot, use power syntax.
singer1812 is offline   Reply With Quote
Old   January 7, 2011, 16:58
It turns out the easiest way to do this is to divide the wall heat flux by the area average of wall temperature minus the volume average of temperature.
Old   May 11, 2011, 02:01
Ade
Ade
Ade is on a distinguished road
Do you mean bulk temperature is defined as volume average of temperature? The bulk temperature would be constant in a domain. Can we use the temperature at far from wall as bulk temperature?
Ade is offline   Reply With Quote
Old   May 11, 2011, 10:14
Edmund Singer P.E.
You can use what ever you want for bulk temperature (as it applies to the h). For a fixed q, changing the bulk temperature will change the h, but you still get the same q.
Now, if you are comparing to literature or empirical expression, you need to define the bulk temperature the same as was done in the literature.
Old   May 11, 2011, 22:04
Ade
Ade
It is true that only wall heat flux is accurate and we need manually define Tb value and calculate HTC.
In my view, Tb is not arbitrary value but has certain physical meaning.
Tb=massFlowAve(T)@section.
Because it is not easy to define the section in software, CFX choose most simple method to deal this problem.
But as end user, why not we use more logical and accurate definition of Tb such as the temperature at main stream?
Old   May 12, 2011, 10:17
Edmund Singer P.E.
Entirely up to you. You can use whatever you want for Tb in CFX and it will give you the appropriate h.
Not all problems have an easily defined free stream temperature.
It is up to the end user to make the choice, based on their problem.
Calculation of the Governing Equations Mihail CFX 7 September 7, 2014 07:27
plot bulk temperature of fluid mohammadkm FLUENT 4 December 13, 2011 16:37
How to install CGNS under windows xp? lzgwhy Main CFD Forum 1 January 11, 2011 19:44
CGNS lib and Fortran compiler manaliac Main CFD Forum 2 November 29, 2010 07:25
Bulk temperature for HTC extimation Italy CFX 4 July 12, 2007 01:05
