January 4, 2011, 09:41 |
Temperature drop in Porous Media?
Sanyo
Rep Power: 17 |
Dear All,
At the outset, Wish you all a Very Happy & Prosperous New Year! I am trying to model a heat exchanger with porous media assumption. It is an HE in the furnace (superheater). I am modeling the flue gas side only. Hence effects of steam have to be approximated. I know the temperature drop in flue gas after passing through the superheater. I am giving the sink value for thermal extraction accordingly. However I am facing two problems due to nonuniformity of the flow. 1. Flue gas temperature is much higher than the expected value. 2. In some cells, where the flow is negligible, temperature of subdomain goes upto "-14" Deg C, which is definitely unrealistic. Is there any way to limit the minimum temp. value inside the subdomain? Can I define my sink term to get the exact temperature drop in flue gases? If yes how? I would appreciate your help. Thanks in advance, Regards, --Sanyo |
January 20, 2011, 02:01 |
So its not possible in CFX?
Sanyo
Rep Power: 17 |
Hi all,
Till date no reply, so shall I assume that whatever I am asking is not possible in CFX? Any help would be highly appreciated. Regards, Sanyo |
January 20, 2011, 04:24 |
Rep Power: 144 |
Yes, you can set the heat source to give you the intended temperature. It has been a while since I did it but I think you define a source of -c(T-Tset) and a source coefficient of -c, where Tset is the desired temperature and c is a constant large enough to make it work.
This has been asked on the forum before, do a search and hopefully you can find it. |
January 20, 2011, 07:56 |
I want specified temperature drop
Sanyo
Rep Power: 17 |
Dear Glenn,
Thanks for your prompt reply. The previous question you are referring was asked by me only. The difference in both problems is that previously I wanted specified temperature throughout the subdomain (Fixed value of temperature like 800Deg C). Now I want specified temperature drop, let us say of 100 Deg C. That I am unable to achieve. Another problem is that due to a constant value specification of sink term, at some cells of subdomain gas temperature reached to "-14" Deg C, which is impossible in water type of heat exchanger. I wish to limit my temperature values also. Thanks for your help. Regards, Sanyo |
January 20, 2011, 20:21 |
Rep Power: 144 |
Oh, you want a specified temp drop, not a specified temp. Sorry, I missed that.
I don't think you can do this with a source. Try an interface, and apply a heat flux on the interface. |
January 21, 2011, 03:29 |
& what about the temperature limit?
Sanyo
Rep Power: 17 |
Dear Glenn,
Thank you very much your reply. I will try the interface flux. But what about the temperature limit? Can't I limit the lower & upper temperature values for domain/ subdomain? My simulation is steady state & fluid is air ideal gas. Regards, Sanyo |
January 21, 2011, 06:29 |
Rep Power: 144 |
You can but it is usually a bad idea as it leads to convergence problems. Better to fix it at the source and stop the spurious temperatures in the first place.
The spurious temperatures are probably caused by your source region and so if you replace it with an interface the problem will go with it. |
January 24, 2011, 09:44 |
Thanks for your support
Sanyo
Rep Power: 17 |
Dear Glenn,
Your suggestions are always extremely helpful. Thanks for your support. Regards, Sanyo |
operating temperature for water in porous media | engahmed | FLUENT | 0 | March 3, 2010 16:21 |
pressure drop in porous media | Dongying Qian | FLUENT | 4 | January 2, 2004 14:38 |
Temperature drop after porous zone | MN | FLUENT | 0 | December 10, 2003 12:28 |
temperature distribution in porous media | Alexey | Siemens | 1 | June 23, 2003 01:11 |
porous media: Fluent or Star-CD? | Igor | Main CFD Forum | 0 | December 5, 2002 15:16 |
