Question about immersed solid method in CFX
Old   January 2, 2011, 20:28
Default Question about immersed solid method in CFX
Shui Pei
spwater is on a distinguished road
Hello:
I am studying immersed boundary method and and try to simulate a ball falling in the water. I am using "immersed solid", is that OK? I find I can give a specified velosity to the ball, but I cannot give a density to the ball and let it fall freely.
What can I do?
thank you!
spwater is offline   Reply With Quote
Old   January 4, 2011, 16:41
Edmund Singer P.E.
singer1812 is on a distinguished road
What are you using the density for in the solid? Having it float in the water? You will need to write that into a CEL expression that controls the motion (velocity) of the ball, or look into using Rigid Body (6DOF), if that is the case.
singer1812 is offline   Reply With Quote
Old   January 4, 2011, 19:52
Shui Pei
Thank you for your reply.
I want to simulate a metal ball fall by gravity in the water.
Where can I selcet the 6DOF solver for a rigid body?
I find little setting opions for a immersed solid.
Old   January 5, 2011, 14:34
Edmund Singer P.E.
What version of cfx are you using? Rigid Body Solver is beta in V12 and full feature in V13.
Beware in V12. You must use the Global coordinate frame as the rigid body coord (there is a bug when it uses a different coordinate system).
Old   January 7, 2011, 11:04
Shui Pei
Thank you for your reply, I am using CFX12.1. Where can I find the relate plane to set the proferty like density for the immersed solid? Sorry for this stupid question, but I am still finding the plan......
Old   May 22, 2012, 09:24
belgacem
belgacem is on a distinguished road
Hello:
I am also studying immersed boundary method and and try to simulate a block falling in the water. I am using "immersed solid" then rigid body 6DOF and I let it fall freely but it can't stoped in the bottom where the velocity must be zero. I give a density to the block and i let it fall freely under gravity. Noted that the rigid body is defined as an immersed solid. i have specified a stationary coordinate frame that has its origin at the center of mass of the physical rigid body. Another fixed coordinate frame was specified related to the water at rest.
What can I do to stopped the rigid body in the bottom where the potentiel energy must be zero?
thank you!
belgacem is offline   Reply With Quote
Old   May 24, 2012, 14:05
belgacem
Hello:
thank you!
Code for Immersed Boundary Method (ask for help) syq129 Main CFD Forum 2 November 23, 2010 04:16
CFX doesn't continue calculation... mactech001 CFX 6 November 15, 2009 22:25
Rigid Body State Variables in Solid Immersed Simulation Hamidreza CFX 1 October 19, 2009 07:14
question about pressure correction method tommewang Main CFD Forum 1 May 19, 2003 09:10
immersed boundary method with unstructured mesh x.zhang Main CFD Forum 0 August 25, 2002 22:57
