Transient post-processing, Time averaged pressure work
Old   January 2, 2011, 18:40
Default Transient post-processing, Time averaged pressure work
Turbomachine is on a distinguished road
Dear All,
I am currently doing the post processing of a transient turbine analysis. I was looking at the previous posts and realised that there were several similar problems that have been raised but remained unsolved. Firstly, the description of the problem is the following:
I have to calculate the work done by the pressure forces on the blade during its movement. Mathematically speaking I need to integrate pressure * mesh displacement over one cycle (100 timesteps) and then plot the work distribution.
In previous discussions the following solutions have been proposed:
1) POWER SYNTAX in CFX-Post:
! @myTimeSteps = ("71","105","136"); # add your "solver steps" between brackets as they are listed in POST "Time Selector"
! $MyVariable = "Water.Superficial Velocity"; # put the variable of interset between quotes
! $MyPlane = "Plane zx"; # put the plane name here
! open(MyOutF,">C:/TimeAvgOut.csv") || die "Can't open file $!\n"; # this will create a Report file named "TimeAvgOut.csv" on root of C:\ drive
! $TStepsNo = @myTimeSteps;
!print MyOutF "Time step , ",$MyVariable, "\n";
! for ($i=0;$i<$TStepsNo;$i++){
> load timestep= $myTimeSteps[$i]
! $MyAvgVel = areaAve($MyVariable, $MyPlane,"");
!print MyOutF $myTimeSteps[$i]," , ",$MyAvgVel, "\n";
! close MyOutF;
The above syntax calculates the area averaged work value at each timestep and stores it in a file.
2) TRANSIENT STATISTICS in CFX-Pre
By setting transient statistics in CFX-Pre it is possible to obtain the time averaged output of variables, however I am not aware of the possibility to include mathematical operators such as p*displ.
Despite the first option what I need is to plot the time averaged work distribution over selected timesteps.
Can anyone suggest a way to achieve this? Thank you for your help!!
Turbomachine is offline   Reply With Quote
Old   January 3, 2011, 18:01
Default Macro
I am using the following macro (suggested by Pavitran in a former discussion) to create a folder and export the data files of the variables I need. The problem is it works for a simple case of a flat plate with 40 nodes but it does not work with a large case with 20000 nodes. When I try to export it from the CFX Post file menu, however, it works fine.
Can someone help me out with this?
#### Name convention
! $PathSeparator = "/";
! $ResFileName = getValue("DATA READER", "Current Results File");
! $ResPos = index($ResFileName, ".res");
! $ResFileLength = length($ResFileName);
! if ($ResPos == ($ResFileLength - 4)){
! $FileBase = substr($ResFileName, 0, $ResFileLength-4);
! else {
! $FileBase = $ResFileName ;
! $DirName = $FileBase . "_EXPORT1"; ##################### ADJUST THIS
! mkdir ($DirName, 0777);
! $DirName = $DirName . $PathSeparator;
#### Start postprocessing loop
! $count = 200; ##################### ADJUST THIS (number of the start imestep)
! @tlistt = (200, 201, 202, 203, 204, 205, 206, …, 300); ##################### ADJUST THIS
! foreach $tlist (@tlistt){
DATA READERATA READER
Current Timestep = $tlist
END
> load
! $dummyfile = $DirName . "t" . $count.".csv";
EXPORT:
#ANSYS Export Data = Element Pressure
#ANSYS Export Locator = wallmeshcdb
#ANSYS Fluid Selection = All Fluids
#ANSYS Reference Temperature = 0.0 [C]
#ANSYS Specify Reference Temperature = Off
Export Type = Generic
#BC Profile Type = Inlet Velocity
Export Connectivity = Off
Export Coord Frame = Global
Export File = $dummyfile
Export Geometry = On
Export Node Numbers = Off
Export Null Data = Off
Export Units System = Current
#Export Variable Type = Hybrid
Include File Information = Off
Include Header = On
Location List = Plane 1 ##################### ADJUST THIS (Inlet, Outlet, Plane1,…) (only one allowed!!!)
Null Token = 0
Overwrite = On
Precision = 10
Separator = ", "
Spatial Variables = X,Y,Z
Variable List = Total Temperature, Total Pressure, … ##################### ADJUST THIS (you can specify more than one variable)
Vector Brackets = ()
Vector Display = Scalar
END
>export
! $count = $count + 1;
# Ende der Sub-Definition
post-processing, pressure, time average, time averaged, transient
Post Processing Transient Data chrisoturner FLUENT 2 August 18, 2017 03:53
calculation diverge after continue to run zhajingjing OpenFOAM 0 April 28, 2010 05:35
Transient Simulation of Oscillating Pressure Waves ylm054 CFX 1 December 4, 2009 06:02
Pressure Inlet Post Processing meshinggod FLUENT 1 November 16, 2009 14:45
Automatic post processing of Transient simulation Aziz CFX 2 June 24, 2005 15:37
