Interface w. Pitch Change:
Old   December 22, 2010, 04:50
Default Interface w. Pitch Change:
Thcfd is on a distinguished road
Hello everyone,
I´m having a small problem with the way CFX stretches or compresses the flowfield when an interface with pitch change is used. Here is my Problem:
I´m currently working on the simulation of a turbine testrig. The rig consists of 4 bladerows of which the 3d one is the rotor. Now, due to the number of blades in each row (and of course time and memory requirements) i´m forced to use interfaces with a pitch change.
When i´m trying to do a simulation with a Frozen Rotor Interface (regardless whether steady state or transient), CFX stretches the flowfield between the interfaces as discribed in the manual. I´ve added two small pictures of a geometry that i used to test different interface configurations, where you can see the stretching cfx performs.
This of course gives a rather wrong flowfield after an interface with a high pitch change (stretching of the wakes etc). In my case the pitch change after the rotor is from 15° to 24°, where the domain with the 24° is the one i´m most interested in. What i have seen from a few things that i have tried is, that CFX is able to "add" information to an interface by periodically adding data to the interface (i tried periodic domains with a different "lean" at the interface).
My question is now whether there is a possibillity to prohibit the stretching on the interface, but to force the solver to do the add the information on side 2 of the interface by periodically copying the information from side 1
I hope that somebody is able to give me any advice or ideas how to solve the issue.
thank you
Thcfd is offline   Reply With Quote
Wind turbine simulation Saturn CFX 60 July 17, 2024 06:45
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 05:05
Pitch Change & interface connections Kumar CFX 2 August 5, 2007 03:57
Stage Interface Without Frame Change Vikram CFX 2 October 21, 2005 05:55
Replace periodic by inlet-outlet pair lego CFX 3 November 5, 2002 21:09
