October 24, 2023, 00:18 |
#81 |
Rep Power: 144 |
This thread discusses many ways to do it.
You can use the <Variable>.Time Derivative method - this is preferred if it works for the variable you want. You can write a user fortran routine to do it. Then you can do anything, but user fortran requires a bit of work to learn to use. You can use the TRANS_LOOP approach. Most of this thread is on this approach, but note it is unsupported and does not seem to work for soem cases.
October 24, 2023, 01:53 |
#82 |
zh
Rep Power: 3 |
I followed the method in this literature but the expression for the last time step I don t know how to determine.
https://www.researchgate.net/publica...l_in_ANSYS-CFX |
October 24, 2023, 02:05 |
#83 |
Rep Power: 144 |
Doesn't that paper and lots of posts on this thread explain how to do it?
If you are having problems with getting it to work then you need to tell us what your problem is (like an error message).
October 24, 2023, 02:51 |
#84 |
zh
Rep Power: 3 |
There seems to be no problem with the setting, the calculation has converged, but the results are not accurate, I calculated the data of three cardiac cycles.
This is my CEL. Beta = C*R2/Deta t Blood Density = 1050[kg/m^3] C = (1.7529*10^(-10))[m^3/Pa] Deta t = 0.02[s] Inlet Flow = Function Inlet Flow 3(t)*Blood Density Normal V = ((w)-(w.Time Derivative*dtstep)) P = (((R1+R2+R1*Beta)*QN+Beta*Previous Outlet Pressure \ -R1*Beta*Previous Outlet Flow )/(1+Beta)) P0 = 96.2327[mmHg] PN = areaAve(Pressure )@OUTLET Previous Flow = abs(areaInt(Normal Velocity )@OUTLET) Previous Pressure = (areaAve(Pressure )@OUTLET-(Pressure.Time \ Derivative*dtstep)) Q0 = 0.39[l/min] QN = abs(areaInt(w)@OUTLET) R1 = (2.4875*10^8)[Pa*s/m^3] R2 = (1.8697*10^9)[Pa*s/m^3] ADDITIONAL VARIABLE: Normal Velocity Option = Definition Tensor Type = SCALAR Units = [m/s ] Update Loop = TRANS_LOOP Variable Type = Specific END ADDITIONAL VARIABLE: Previous Outlet Flow Option = Definition Tensor Type = SCALAR Units = [ml/s] Update Loop = TRANS_LOOP Variable Type = Volumetric END ADDITIONAL VARIABLE: Previous Outlet Pressure Option = Definition Tensor Type = SCALAR Units = [mmHg ] Update Loop = TRANS_LOOP Variable Type = Specific END |
October 24, 2023, 03:23 |
#85 |
Rep Power: 144 |
There is a LOT more to getting an accurate result than a bit of CCL. Did the calculations of the previous values you included work?
October 24, 2023, 03:30 |
#86 |
zh
Rep Power: 3 |
I use the data in the literature, but there is a big gap between my results and the literature, so I think there is still a problem with the expression of my export flow. I use the area score of the normal speed of the export, but this seems to have a certain error with the expression of CFX: massFlow() @OUTLET / Blood Density.
April 11, 2024, 06:19 |
#87 |
Jiri
Rep Power: 13 |
Hello guys,
for some kind of reason, the approach based on creating the expression with .Time Derivative does not work. I tried Pressure.Time Derivative, Velocity u.Time Derivative, Temperature.Time Derivative... I always get the error message about unrecognised name. I save each time step. Is there needed any special setting in CFX Pre ? Do you have any idea please? |
April 11, 2024, 06:46 |
#88 |
Rep Power: 144 |
Can you attach the CCL of your simulation? You can export this from CFX-Pre.
April 11, 2024, 06:58 |
#89 |
Jiri
Rep Power: 13 |
Please, see the attachment..
April 11, 2024, 18:09 |
#90 | |
Rep Power: 33 |
April 12, 2024, 02:53 |
#91 |
Rep Power: 18 |
April 12, 2024, 06:15 |
#92 |
Jiri
Rep Power: 13 |
Yes, the version 2022 R2. However, version 2023 R2 does not work either (I opened the results in CFD Post). But I do not think it is matter of version as this did not work to me even a few years ago.
May that be some defaults, e.g. something dug in inside the expert parameters? |
April 12, 2024, 09:00 |
#93 |
Rep Power: 33 |
That should work; however, the answer is conditional.
.Time Derivative ONLY works in the CFX-Pre/Solver environment. It does NOT work in CFD-Post unless the variable is already written by the solver. Then, where are you trying to use it? CFX-Pre, or CFD-Post.?
April 15, 2024, 08:53 |
#94 |
Jiri
Rep Power: 13 |
I am sorry for the late answer. I did it also in CFD Pre as expression:
Pressure.Time Derivative But when clicking on this in CFD Post, it says: The following unrecognised name was referenced: Pressure.Time Derivative. I tried also areaAve(Velocity u.Time Derivative)@rotating in CFX Pre, as the previous case is "variable", but there is still the same error in CFD Post. |
April 15, 2024, 13:26 |
#95 | |
Rep Power: 33 |
It seems you were able to finish the simulation using XXx.Time Derivative in your expressions, correct?
April 15, 2024, 15:00 |
#96 |
Jiri
Rep Power: 13 |
April 17, 2024, 12:49 |
#97 |
Jiri
Rep Power: 13 |
Any ideas please? May I share the file with you to test it? Or vice versa, if some of you could share the cfx file where it works...
April 17, 2024, 14:05 |
#98 |
Rep Power: 33 |
CFD-Post does not support those variables, XXX.Time Derivative UNLESS they ARE already in the results file.
April 18, 2024, 05:02 |
#99 |
Jiri
Rep Power: 13 |
Opaque, thank you for clarifying.
So, to sum it up again, how shall I understand it - I defined the variable "Pressure.Time Derivative" in Pre, then ran the solver and opened the result file in CFD Post. But for some reason this variable does not work in CFD Post. I understood that situation to be strange and that it should work. Or, please, did I miss some step in between? |
April 18, 2024, 06:49 |
#100 |
Rep Power: 144 |
Have you tried going to the CFX-Pre output tab and putting [variable].Time Derivative in the results file? It looks like by default they are not included in the results file.
Cel expressions | RAMAN6089 | CFX | 13 | December 1, 2009 00:17 |
junction box routine and CEL function | bornspur | CFX | 2 | February 3, 2009 03:24 |
Cel expressions for trasient problem | Jervds | CFX | 0 | March 4, 2008 11:03 |
Cel expressions Time dependent | Juan Maria Campos | CFX | 8 | December 27, 2007 19:16 |
CEL Expressions | Nick | CFX | 3 | September 25, 2007 15:54 |
