Adequate timestep selection for multidomain problem |
November 27, 2010, 15:37 |
G. S.
Rep Power: 16 |
I'm setting up a multidomain (solid and fluid) transient simulation of a furnace (involving combustion) where I wanna know how much time is needed to get certain temperature in part of a solid domain (according to the experimental data is 4 hours).
I selected a timestep of the order of 1e-04 as the initial timestep and a factor of 10 to increase it, but after severeal timesteps calculations this timestep hasn't been increased yet (after 30 timesteps aprox.). So my question is, how can i achieve the result i desire using a higher timesteps with a good phisical accuracy, because if the initial timestep doesn't increase i will never get the Total time of the simulation (aprox. 4 hours). Thanks in advance. |
November 27, 2010, 20:58 |
Rep Power: 144 |
What are you using as your adaptive time step critereon?
November 27, 2010, 21:20 |
G. S.
Rep Power: 16 |
I'm using the Number of Coefficient Loops method....
I tried switching to a timestep list with the number and the value of timesteps over my whole simulation and combustion never started...I'm using EDM and I don't know why combustion doesn't starts, as a solution I included a source point with the double of the activation energy as the source value with any satisfactory result... Any advice on my problem will be very welcome...thanks in advance ghorrocks... |
November 28, 2010, 15:05 |
Rep Power: 17 |
always the same misunderstandings . First I would use "pure" EDM. Check the model equations in order to understand why pure EDM for premixed flames cannot be ignited by temperature or enthalpy.
November 28, 2010, 15:24 |
G. S.
Rep Power: 16 |
Yes....well i have already solved that isssue turning -1. the B coefficient (producto limiter), i had a value of 0.5 to control combustion
November 28, 2010, 17:50 |
Rep Power: 144 |
For single phase simulations you usually aim to get 2-5 or 3-5 coeff loops per iteration. For multiphase and combustion you will probably have to increase it, maybe 5-10 loops per timestep. But you might want to have some fine and constant time steps when you start the combustion.
November 28, 2010, 18:50 |
G. S.
Rep Power: 16 |
Thanks for the help i'll struggle to get this done efficiently
Solver Selection with COMSOL | S. Gatzka | COMSOL | 1 | January 27, 2008 17:35 |
Timestep selection | Jindra Kosprdova | CFX | 9 | April 28, 2005 07:41 |
timestep selection | Florian | CFX | 15 | December 9, 2003 19:26 |
extremely simple problem... can you solve it properly? | Mikhail | Main CFD Forum | 40 | September 9, 1999 10:11 |
Is this problem well posed? | Thomas P. Abraham | Main CFD Forum | 5 | September 8, 1999 15:52 |
