Nick
Rep Power: 15 ![]() |
Hi ALL
I'm trying to simulate flow over a flat plate (Laminar Steady State). I have a box as my domain whose bottom is defined as Wall and its left side is the inlet. I have set the inlet to a certain normal velocity (0.001 m/s). However when the computation has converged and I plot the velocity vectors at the inlet I notice that next to the region where the inlet and the wall meet I get velocity vectors pointing upwards so the velocity at inlet is no longer the value I set before. I know this is supposed to be true away from the inlet because of the presence of boundary layer but I get this AT THE INLET! Why does CFX change my Boundary Condition? What can I do to fix this? Thanks in advance Nick R |
Rep Power: 144 ![]() ![]() ![]() ![]() |
You apply boundary conditions on element faces but the velocity vectors are from control volume centroids. You specified the inlet velocity at the element face but the first control volume centroid has a normal component as it tries to sort the boundary layer out.
Rep Power: 17 ![]() |
For some post-processing operations you have the choice between "conservative" and "hybrid" (which is also conservative). Don`t have in mind if you have this also for vector plots. If yes you should change to hybrid.
Nick
Thank you guys. Very helpful.
Boundary Layer of Laminar Flow over a Flat Plate | Blasius_Pohlhausen_Crocco | Main CFD Forum | 12 | September 30, 2013 17:35 |
Low Reynolds Number Flow over a Flat Plate | Go | FLUENT | 4 | August 28, 2013 05:19 |
incompressible, 2-D laminar flow over flat plate... | varunjain89 | Main CFD Forum | 3 | March 6, 2012 11:13 |
laminar flow on flat plate | AmirFluid | Main CFD Forum | 7 | June 22, 2010 05:49 |
2d supersonic flow over flat plate | puzzled | Main CFD Forum | 2 | March 17, 2004 18:07 |
