November 4, 2010, 22:25 |
meaning of surface streamlines
Nick
Rep Power: 16 |
This may be a trivial question but I'm new to CFD. In CFX post you can plot surface streamlines. Given the fact that velocity is zero on solid walls (hence no streamlines there) what does this option represent? Also how can you get 2D views(x-y, y-z etc) in CFX post? Clicking on the axes don't work. Should these planes be defined? Thanks. Nick R |
November 5, 2010, 06:06 |
Rep Power: 144 |
Surface streamlines follow the wall shear stress vector.
To create 2D views put in a slice plane. Then you define the plane location and off you go. |
November 5, 2010, 06:14 |
Nick
Rep Power: 16 |
Thanks so it represents the shear force on the wall.
November 5, 2010, 16:17 |
Rep Power: 144 |
That's right. If you put an oil drop on the surface it is where the wind will blow it.
[Gmsh] Error : Self intersecting surface mesh, computing intersections & Error : Impossible | velan | OpenFOAM Meshing & Mesh Conversion | 3 | October 22, 2015 12:05 |
[Gmsh] Problem with Gmsh | nishant_hull | OpenFOAM Meshing & Mesh Conversion | 23 | August 5, 2015 03:09 |
[Gmsh] boundaries with gmshToFoam | ouafa | OpenFOAM Meshing & Mesh Conversion | 7 | May 21, 2010 13:43 |
Surface streamlines on axial flow fans | Jennifer | CFX | 2 | February 17, 2009 15:50 |
CFX4.3 -build analysis form | Chie Min | CFX | 5 | July 13, 2001 00:19 |
