Rotating plate.
Old   November 4, 2010, 18:07
Default Rotating plate.
Farzan
farrr is on a distinguished road
Hi everyone,
I'm trying to model two rotating discs with some radial plates between them, with axial flow.
The picture shown here:
Inlet mass flow is used in the bottom, outlet pressure in the end and rotational periodic in each side. All the walls are rotating around the x axis.
I have no problem with modeling just two rotating discs but when I add the radial plate to the geometry, I get this error at the the first step of solver.
| ERROR #002100080 has occurred in subroutine CHECK_NORMV.
| Message:
| The specified velocity vector on the boundary patch
| Default Domain Default
| has a significant normal component at one or more faces. One of
| these face locations is
| (x,y,z) = ( 4.43340E-03, 3.68905E-02, 5.00000E-04).
| The angle between the specified velocity and the element surface is
| 89.217 degrees at this face. This is considered an error because
| it implies that the mesh is moving. The following are possible
| reasons for the error message:
| 1. There is a setup error; for example, an incorrect axis of
| rotation.
| 2. There may be a meshing problem; for example, the nodes on a
| rotating surface might not lie on the surface of revolution.
3. The boundary is curved and the mesh is very coarse. In this
| case, you may increase the tolerance for this check by
| increasing the expert parameter 'tangential vector tolerance'
| from its default of 20 degrees.
The location (x,y,z) refers to the a point at the end of the plate.
P.S. I refined the mesh in that spot but it didn't work.
farrr is offline   Reply With Quote
Old   November 5, 2010, 11:47
stumpy is on a distinguished road
What's your rotation axis? I assume you need to use MFR for this. In a rotating domain, any counter-rotating walls must be tangential to the rotation direction. In a stationary domain, any rotating walls must be tangential to the specified velocity direction.
stumpy is offline   Reply With Quote
Old   November 5, 2010, 11:49
Michael P. Owen
michael_owen is on a distinguished road
You need to put the system in a rotating frame of reference and apply counter-rotating wall velocities to the fixed walls, instead of attempting to apply a rotating wall velocity to the rotating plate. The wall velocity has to be tangent to the wall, otherwise the system is not stationary.
michael_owen is offline   Reply With Quote
Old   November 5, 2010, 13:03
Farzan
Thank you folks. I'll try that.
Old   October 17, 2011, 23:53
zzr
flilk is on a distinguished road
is it work ?
now i have a same problem,and have no idea
flilk is offline   Reply With Quote
Old   October 19, 2011, 19:30
Farzan
It was long time a go. But I think it worked.
Old   October 20, 2011, 03:48
zzr
toaday ,i use the rotating frame and counter-rotating wall to define the simulation,but the same problem is occour.i want to know what you did in your work.
Old   July 20, 2015, 15:24
Thiagu
jthiakz is on a distinguished road
counter rotating wall's mesh is coarse hence surface normal are >25 (cfx default). Refining could be an option or removing 3D features
jthiakz is offline   Reply With Quote
Rotating Impeller Naith FloEFD, FloWorks & FloTHERM 22 November 5, 2012 09:53
vibration of a rotating plate in water zhm Main CFD Forum 0 March 2, 2010 19:50
heat transfer on dimpled plate mech FLUENT 4 February 6, 2007 16:15
Parallel Plate Rheometer vs Cone & Plate beginner Main CFD Forum 0 March 19, 2003 12:49
jet on rotating plate A.TOUZANI Main CFD Forum 0 January 30, 2003 11:05
