Setting Pressure Boundary Conditions in ANSYS CFX Pre
Like Tree2Likes
Old   February 22, 2017, 07:07
Default Pressure Boundary Condition CFX Pre
  #21
AS_Aero is on a distinguished road
Hi All
I have a similar issue:
I am using a pipe flow where I have at inlet a mass flow rate of 2 L/min and an operating pressure of 6 bar and the flow is passing through a diffuser to the outlet atmosphere. So I would like to know what kind of BC'n can I give !
At the inlet I need to give this 6 bar or mass flow rate of the water
But at the outlet what pressure value should I specify
Also the reference pressure value ? I am confused about this pressure value thing.
This 6bar at the inlet is provided by a barometer reading just before the inlet of the pipe. That means its the operating pressure and it has a flow rate of 2 L/min.
Now what should I specify for the outlet BC'n. (The flow is into the atmosphere)
AS_Aero is offline   Reply With Quote
Old   February 22, 2017, 17:50
If it diffuses to atmosphere and atmospheric pressure is part of your simulation then use atmospheric pressure as the reference pressure. Then you can apply on the inlet either a flow rate of 2 L/min or a pressure of whatever the gauge pressure is. Note the flow rate boundary will be more numerically stable so I would use that if possible.
symmetry boundary conditions in cfx lost.identity CFX 41 May 22, 2013 08:21
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 05:05
Pressure Boundary Conditions kantipudi Main CFD Forum 1 August 10, 2008 05:07
help setting up boundary conditions for combustor Tomas CFX 2 November 3, 2005 04:34
Hydrostatic pressure in 2-phase flow modeling (long) DS & HB Main CFD Forum 0 January 8, 2000 16:00
