Is CFX incapable of modelling a compression ramp in 2D?
Old   November 1, 2010, 12:11
Michael P. Owen
michael_owen is on a distinguished road
Run it in double and see if that crazy artifact goes away.
michael_owen is offline   Reply With Quote
Old   November 1, 2010, 17:45
To me it looks like it is generating a shock wave off the start of the wall. I would move the inlet boundary further upstream so the flow can settle down by the time it reaches the area of interest.
ghorrocks is online now   Reply With Quote
Old   November 6, 2010, 08:01
RossFS is on a distinguished road
Glen: Doing that allows the simulation to run with no problems at all, but what is causing the shock off the wall in this instance is the specification of a boundary layer profile. This occurs even if the boundary layer profile is generated from the end of a duct flow of the same height by CFX which is really odd.
The problem however is that in order for the simulation to match the experimental conditions as close as possible, the boundary layer profile must be specified.
Admittedly, the boundary layer profile I specified did not deal with the viscous and buffer regions on the boundary layer accurately, but even so CFX appears to over ride the boundary layer profile I put in close to the wall anyway (maybe because of this). This I know from a graph of the velocity profile at the inlet.
This is the case with the RNG k-e and SST k-w models with a mesh as refined as y+ at the wall of <1.
Will try specifying a more accurate boundary layer profile.
Something really odd with CFX that I've recently noticed is the lack of a 0m/s velocity at the wall even though it is no slip. The graphics of the flow (a false colours contour plot) does not indicate that this is the case, although a graph or a .csv file indicates otherwise. This is not as big a problem with a more refined (y+ at wall <1) mesh, but the velocity is still 30m/s or so which is wrong.
RossFS is offline   Reply With Quote
Old   November 7, 2010, 18:32
This is because of the control volumes in CFX. It is not an error, it is because CFX does not have a control volume centroid at the wall, so the boundary nodes have a finite velocity. The no-slip boundary is applied to the faces of the control volume. Read the documentation about conservative and hybrid values.
compression ramp
supersonic flow past compression ramp yapalparvi OpenFOAM Running, Solving & CFD 1 June 14, 2017 12:13
Pros and Cons for CFX, CFdesign, COMSOL Val Main CFD Forum 3 June 10, 2011 03:20
OpenFOAM vs. Fluent & CFX marco Main CFD Forum 81 March 31, 2009 15:22
VIV Modelling in FLUENT or CFX? Sham Main CFD Forum 1 July 4, 2007 05:55
CFD Short Course & CFX User Day Chris Reeves CFX 0 September 11, 2000 09:53
