CFX Parameters Settings
Old   October 28, 2010, 05:44
Danny
Flaky is on a distinguished road
Originally Posted by michael_owen View Post
What values are you refering to? The solution values or the residual values? If the latter stop changing, the solution may not be converged if they are still high. Also, the solution has converged once the convergence criteria have been reached AND imbalances are negligable AND bulk quantities like pressures, velicities and temperatures have stopped changing, not "or".
The imbalances you speak about is referring to Global balance am i right.
You also mention Bulk quantities like pressures, velicities and temperatures have stopped changing. Correct me if i am wrong. But this would be for steady state where the above qualities stop changing.
If i am doing a transient simulation as long as the Residual target and the conservation target are met or below the target value and they stop changing after each iteration, i can consider it as converged?
I have also set monitoring points in terms of temperature.
Is there a difference for the setting for Temperature and Total Temperature? For my case of heat transfer.
Flaky is offline   Reply With Quote
Old   October 28, 2010, 19:16
Bulk quantities changing also applies to transient simulations. As the solver iterates to a solution for a given timestep it adjusts the P, V, T fields to obtain convergence. So you need to make sure these values are not changing inside the current timestep before you can declare this timestep converged and move to the next one.
ATTENTION! Reliability problems in CFX 5.7 Joseph CFX 14 April 20, 2010 16:45
Different flow pattern between OpenFOAM and CFX AirS OpenFOAM 0 January 12, 2010 08:08
heat generation in CFX Ema CFX 4 August 7, 2009 06:39
Electronics Enclosure Analysis with CFX Simulation Engineer CFX 1 April 22, 2009 12:08
CFX 10's solutions differ from CFX 5.7's Atit Koonsrisuk CFX 4 July 26, 2006 12:59
