Interface Model:None or zero thermal conductance?
Old   October 10, 2010, 11:16
Default Interface Model:None or zero thermal conductance?
mak86 is on a distinguished road
Dear all,
In defining domain interfaces in CFX there are 3 options for interface model: None,Thermal conductance and Thin Material.
what is the difference between choosing none or a zero thermal conductance?
I have solved the same problem with these two options and I got different results.
Thanks
mak86 is offline   Reply With Quote
Old   October 11, 2010, 05:04
anton.gardi
gardian is on a distinguished road
I think you should have a look in the help . the physics is different in every case. in case you have a solid immersed in a fluid you should check also what the conjugate heat transfer is ..
gardian is offline   Reply With Quote
Old   October 11, 2010, 15:41
I read the documentation but there is no description for the none option.
The two others do the same job in different ways.
"Heat Transfer
Determines whether or not heat transfer models are applied between the sides of the interface.
The options are:
  • Conservative Interface Flux
    This option enables you to define the Thermal Contact Resistance or Thin Material, which are two ways of defining the same characteristics. That is, if you do not know the contact resistance, you can define the thin material and its thickness and have the solver derive the resistance"
Old   October 11, 2010, 19:09
None means no interface material, and heat is transferred across the interface with no loss or resistance. The other options add thermal resistance, they just calculate the thermal resistance different ways.
Old   October 12, 2010, 02:43
Dear ghorroks,
If so None and a zero thermal resistance must give the same result, I have tried this and the results were different!
Old   October 12, 2010, 19:18
I have not used these options so do not know in detail. But I would have assumed zero thermal resistance then should be the same as the none option. If you have a case which shows it is not the same then talk to CFX Support as you may have found a bug.
Old   October 12, 2010, 23:15
Michael P. Owen
michael_owen is on a distinguished road
Originally Posted by mak86 View Post
Dear ghorroks,
How different? Provide plots.
michael_owen is offline   Reply With Quote
Wind turbine simulation Saturn CFX 60 July 17, 2024 06:45
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 05:05
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 16:55
Replace periodic by inlet-outlet pair lego CFX 3 November 5, 2002 21:09
Info: Short Course On Thermal Design of Electronic Equipment Arnold Free Main CFD Forum 0 August 10, 1999 11:18
