Dynamic meshing in CFX: (negative volume error) |
October 18, 2010, 07:52 |
#21 |
Michael P. Owen
Rep Power: 17 |
Check your working directory in the cfx launcher. Make sure it points to where the def and ICEM files are located.
October 18, 2010, 16:53 |
mesh morphology
#22 |
Ugly Kid Joe
Rep Power: 16 |
Does anyone know what mesh morphing actually is ??? A ppt on the ANSYS site talks about mesh morphing being used for large mesh deformation and to avoid re-meshing.I gives the example of ball valve and butterfly valve tutorial. My case is very similar to the ball valve.
But I cannot find any particular tutorial or theory on it ??? Thank you. |
October 18, 2010, 18:45 |
#23 |
Rep Power: 144 |
The CFX tutorial titled "Fluid Structure Interaction and Mesh Deformation" sounds like a good place to start. There are several other moving mesh tutorials which come with CFX.
April 2, 2020, 12:06 |
#24 |
Brett
Rep Power: 14 |
Hey guys,
I'm not using any dynamic or moving mesh and I"m still getting this error. I'm trying to mesh for a centrifugal compressor. Any thoughts? |
April 2, 2020, 16:44 |
#25 |
M
Rep Power: 13 |
If you get this error but don't use moving mesh, your mesh is bad in the first place or am I missing something. Did you check your mesh quality prior to starting the simulation?
April 2, 2020, 19:19 |
#26 |
Rep Power: 144 |
As AtoHM states, your mesh must have an element which has turned inside out. Go back to your meshing software and do some mesh quality checks. You should be able to find the bad elements. How to fix it will depend on what meshing software you are using, but you need to generate a mesh which does not have any inside out elements.
Building OpenFOAM1.7.0 from source | ata | OpenFOAM Installation | 46 | March 6, 2022 14:21 |
[OpenFOAM] Native ParaView Reader Bugs | tj22 | ParaView | 270 | January 4, 2016 12:39 |
Compile problem | ivanyao | OpenFOAM Running, Solving & CFD | 1 | October 12, 2012 10:31 |
negative cell volume during dynamic meshing | Tamjid | FLUENT | 1 | September 5, 2011 03:33 |
compile errors of boundary condition "expDirectionMixed" | liying02ts | OpenFOAM Bugs | 2 | February 1, 2010 21:11 |
