Simulation speed increase
Old   October 7, 2010, 10:54
Alexander U.
FoxTwo is on a distinguished road
and now the earth is rotating again in a right direction
FoxTwo is offline   Reply With Quote
Old   October 7, 2010, 11:09
Attesz's Avatar
Attesz
Attesz is an unknown quantity at this point
thanks
Attesz is offline   Reply With Quote
Old   October 7, 2010, 11:28
Lance
Lance is on a distinguished road
There is an expert parameter which allows you to output wall clock time in the output, should be useful in your case.
Wall clock time = t
Lance is offline   Reply With Quote
Old   October 7, 2010, 12:14
Attesz's Avatar
Attesz
ok, i'll try it, thanks!
Old   October 13, 2010, 10:55
Attesz's Avatar
Attesz
OUTER LOOP ITERATION = 1662 ( 217) CPU SECONDS = 9.807E+05 (2.258E+05)
| Equation | Rate | RMS Res | Max Res | Linear Solution |
| U-Mom | 1.16 | 5.1E-04 | 3.6E-01 | 4.8E-03 OK|
| V-Mom | 1.04 | 2.2E-04 | 1.2E-01 | 7.4E-03 OK|
| W-Mom | 1.18 | 1.8E-04 | 1.0E-01 | 7.3E-03 OK|
| P-Mass | 2.59 | 1.5E-05 | 1.1E-02 | 5.0 5.0E-02 OK|
| H-Energy | 0.70 | 9.1E-05 | 7.8E-02 | 6.1 1.1E-02 OK|
| K-TurbKE | 1.13 | 1.1E-04 | 6.1E-02 | 6.0 2.3E-03 OK|
| O-TurbFreq | 1.06 | 4.1E-05 | 2.4E-02 | 12.6 4.3E-05 OK|
Execution terminating: STP file found.
CFD Solver finished: Wed Oct 13 14:21:43 2010
CFD Solver wall clock seconds: 7.5005E+04
Here, the wall clock seconds means the required time for the solution only, or the partitioning etc is involved?
cores, memory allocation factor
Solar Radiation in OpenFOAM plainstyle OpenFOAM Running, Solving & CFD 15 July 8, 2014 05:43
UDF to change Rotation Speed in a MRF simulation Mike FLUENT 3 September 27, 2011 07:46
Best Pc Configuration for maximum simulation speed Anastasios Georgoulas FLUENT 2 December 18, 2008 13:34
How to Increase Speed? steve podleski Main CFD Forum 23 January 11, 2000 16:41
3-D Contaminant Dispersal Simulation Apple L S Chan Main CFD Forum 1 December 23, 1998 11:06
