September 27, 2010, 14:29 |
Several Inexplicable Errors
Joshua Counsil
Rep Power: 18 |
Good day, all -
One of my simulations stopped unexpectedly with the following three errors: +--------------------------------------------------------------------+ | ERROR #001100279 has occurred in subroutine ErrAction. | | Message: | | setfilebusyflag: permission denied for zFas3A4b | +--------------------------------------------------------------------+ | ERROR #001100279 has occurred in subroutine ErrAction. | | Message: | | iocnt: setfilebusyflag failed when writing a data set header | +------------------------------------------------- ERROR #001100279 has occurred in subroutine ErrAction. | | Message: | | WriteLong: write header failed: what=G/ORTHANGLE I couldn't find any information regarding these errors on this website, Google, or the Help files. Any ideas? Thanks! |
September 27, 2010, 19:09 |
Rep Power: 144 |
CFX has lots of incomprehensible error messages. You can only have a guess at what they are getting at.
Looks like it is having problems writing some sort of file. What physics are you using to generate this? Are you sure the file permissions are OK? Plenty of disk space? |
September 27, 2010, 21:47 |
Joshua Counsil
Rep Power: 18 |
I'm performing a low-Reynolds-number flow simulation over an airfoil. Nothing special about it.
I don't understand your "file permissions" question, I'm afraid. There is plenty of disk space. The error doesn't seem to have reappeared after restarting the simulation from the last written .trn file. |
September 28, 2010, 07:41 |
Rep Power: 144 |
I see. Some physics models write temporary files as they work - but I don't think yours will be doing that so I have no idea what the error is talking about.
The MMS (Memory management structure - where all data is stored internally in CFX) is arranged in a directory structure, could it be there is some problem with the MMS? Just a guess, and no idea what to do if it was anyway. |
September 28, 2010, 11:09 |
Joshua Counsil
Rep Power: 18 |
There could be a problem with the MMS, but I doubt it since three other simulations are successfully running/writing from/to the same location. Still, the problem hasn't reappeared since, so I'm hoping it was just a one-time occurrence.
Thanks! |
October 22, 2010, 18:00 |
Joshua Counsil
Rep Power: 18 |
ANSYS got back to me about this error. Solver sometimes writes .lck (lock) files when a simulation crashes, for example. These .lck files are supposed to be deleted automatically when the simulation resumes. In my case, however, they weren't. This caused problems when writing the .res files. I simply deleted all the .lck files on my computer and the problem was solved.
October 23, 2010, 11:27 |
#7 | |
jarrai
Rep Power: 16 |
I got the same ERROR #001100279,so i am trying to delete all the .lck files on my computer but the computer can not delete the .lck files,because can not read the source files. What i have to do? |
October 23, 2010, 17:24 |
Joshua Counsil
Rep Power: 18 |
This is more of a general Windows question than a CFD question. Have you tried searching for your problem on Google?
http://www.spywareinfoforum.com/inde...howtopic=74300 |
Building OpenFOAM1.7.0 from source | ata | OpenFOAM Installation | 46 | March 6, 2022 13:21 |
How to write k and epsilon before the abnormal end | xiuying | OpenFOAM Running, Solving & CFD | 8 | August 27, 2013 15:33 |
Convergence moving mesh | lr103476 | OpenFOAM Running, Solving & CFD | 30 | November 19, 2007 14:09 |
IcoFoam parallel woes | msrinath80 | OpenFOAM Running, Solving & CFD | 9 | July 22, 2007 02:58 |
Could anybody help me see this error and give help | liugx212 | OpenFOAM Running, Solving & CFD | 3 | January 4, 2006 18:07 |
