Momentum Source for fan
Old   September 27, 2010, 15:21
Default Momentum Source for fan
Chrome
TX_Air is on a distinguished road
I am trying to predict temperature profile in a duct right after an electric heater. At the end of this duct there is a plenum/centrifugal fan. This fan draws air through electric heater and releases it in a large chamber/cabinet area. I am confuse about modeling fan part as a momentum source to account for pressure increase in fan. Right now if I don't model the fan and just apply the CFM at the exit I see some reverse flow and model never converges. Can some one point me to right direction on how to do calculation to account for fan pressure rise/momentum source and how to apply them in CFX. Direction to the right tutorials will be appreciated too.
I know that fan imposes 3.25 inH20 (802.66 Pa) pressure rise at 8000CFM (4.22 kg/sec) air. Shall I just use the interface at the fan exit face and add a pressure change?
Thanks
TX_Air is offline   Reply With Quote
Old   September 27, 2010, 20:55
It is better if you have a fan curve, what you have specified is just a single operating point. The fan will either run faster or slower than depending on conditions.
Why are you modelling the fan at all? Can't you model the fan as a mass flow outlet with 8000CFM flow? That is much easier. If you are having convergence problems see here: http://www.cfd-online.com/Wiki/Ansys...gence_criteria
Old   September 28, 2010, 11:32
Chrome
Glenn,
Thanks for your reply. I am running a simulation without fan and specifying just MFR and it is working just fine. I was very curious as how to use general momentum source.
I have a full fan curve. But the test data for heater we tested was available only on two fan operating points. In my application CFM will not change for this test.
Thanks
Old   September 28, 2010, 19:52
Yes, but what CFM to use? The CFM the fan pulls depends on the system. Unless you know what CFM the fan pulls in the system you should use the fan curve.
What test data for the heater are you referring to? Heat transfer or resistance/pressure drop?
Old   September 29, 2010, 16:58
Chrome
This simulation is for an air conditioning machine. So when they run the test they try at 3 or 4 different CFMs. Most of the time their application envelope is on the right hand side of the peak efficiency for FC (Forward Curve) or Plenum fans. That is why CFM was constant here. As far as the heater data is concerned. I Was talking about a temperature profile downstream. They had a 15 thermocouple grid located around 10" down the heater and then fan. I am trying to compare my results to that thermocouple grid through monitor points.
Since we are already on this topic. When I was applying boundary condition to heater's heating element surface, I noticed two methods to apply heat source. One was on the boundary source. Which gave me 3 options for source. 1. Heat Flux, 2. Temperature, 3. Heat Transfer co-efficient.
Second was through equation source, and that is what I am doing right now. Applying source to energy equation.
I am wondering what is the difference between these two methods.
One more thing. Let's say I have fan map/fan curve which will give me RPM, CFM, Static pressure rise, fan's static efficiency. How do I go about using this information for fan source. If someone can explain me calculations that would be great.
Old   September 29, 2010, 19:42
What two methods?
You create a function, probably a 1D interpolation function which links pressure rise to CFM. Then make a region on the fan inlet to calculate flow rate. In the sub-domain for the fan you then make a momentum source which generates a pressure rise from the interpolation function and current flow rate.
cfx 12.1, fan in hvac, general momentum
wmake compiling new solver mksca OpenFOAM Programming & Development 14 June 22, 2018 07:29
Mass source, Momentum source theory. diffo FLUENT 4 August 21, 2009 11:26
Problem with Mass source, Momentum source theory diffo Fluent UDF and Scheme Programming 0 August 20, 2009 07:10
DxFoam reader update hjasak OpenFOAM Post-Processing 69 April 24, 2008 02:24
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 18:51
