September 27, 2010, 01:40 |
volume concentration
seok jun
Rep Power: 16 |
I have some queation using CFX.
Dispersion problem. rectangle box. initial condition : air in rectangle box boundary condition : inlet(Hydrogen mass flow), openning 1. I can not fine volume concentration in CFX-post. (just mass concentration, mass fraction) 2. How conversion to volume concentration. |
September 27, 2010, 07:33 |
Rep Power: 144 |
You can calculate it from the mass fraction and molar masses of the components. I will leave the derivation of the equation up to you from there.
September 27, 2010, 08:03 |
seok jun
Rep Power: 16 |
Thank you for your comment.
But I don't know conversion equation. |
September 27, 2010, 08:11 |
Rep Power: 144 |
September 27, 2010, 08:27 |
seok jun
Rep Power: 16 |
I need to Hydrogen Volume Concentration (Vol %).
(Time series value on sensor(points)) Hydrogen density : 0.09 Air density : 1.205 If the sample is a mixture containing N components, the molar volume is calculated using ~~~/ what is the Xi? |
September 30, 2010, 04:42 |
Matthias Voß
Rep Power: 20 |
hi
if V is m3/mol and M is mol what could possibly x_i be? It is Mass_i/Total_Mass (MassFraction), and if you sum up over i components you end up in a weighted Molar Mass. This divided by the weighted Density of the Mixture is the Molar Volume. neewbie P.S.: next time i´ll find the Latex button in the beginning. Last edited by mvoss; September 30, 2010 at 09:06. |
May 13, 2021, 08:44 |
#7 | |
Rep Power: 5 |
I have same case. However, I am using fluent. How did you find mass concentration there? |
May 14, 2021, 04:42 |
Gert-Jan
Rep Power: 28 |
Possibly fluent can do it for you.
After running the case in the menu "Run Calculation", you can find the button "Data File Quantities" with which you can control the variables that are written to the dat-file. Isn't the variable you're looking for present in the long list? |
May 14, 2021, 09:49 |
#9 | |
Rep Power: 5 |
Thank you for your response. I checked Data File Quantities. They have a molar concentration in mol/m3. However, I need it in percentage. I checked online a lot. But equations are too confusing. I am getting 40 mol/m3 H2 molar concentration. Can you please help to convert it into a percentage? |
volume concentration |
[blockMesh] BlockMesh FOAM warning | gaottino | OpenFOAM Meshing & Mesh Conversion | 7 | July 19, 2010 15:11 |
On the damBreak4phaseFine cases | paean | OpenFOAM Running, Solving & CFD | 0 | November 14, 2008 22:14 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 12:55 |
[blockMesh] Axisymmetrical mesh | Rasmus Gjesing (Gjesing) | OpenFOAM Meshing & Mesh Conversion | 10 | April 2, 2007 15:00 |
particle number concentration in a volume | DH | FLUENT | 0 | March 2, 2007 16:01 |
