Temperature dependent on air properties
Old   September 9, 2010, 12:25
Question Temperature dependent on air properties
WIROTE
Reto is on a distinguished road
I am working on natural convection on a vertical heated plate. I set the plate temperature high (~700 K), so it seems that the flow over the plate is turbulent flow. These are my questions:
1. Most of properties for Air 25 C have constant value. Is there the built-in properties of the air depending on temperature?
2. What value of y+ should I use in meshing procedure for simulating the viscous sublayer?
Please give me suggestions. Thank you in advance!
Reto is offline   Reply With Quote
Old   September 9, 2010, 19:52
1) No. You will have to define it yourself.
2) You need to do a sensitivity study to establish this. Are you sure you need to model the sublayer? You might be turbulent enough that wall functions are OK and then meshing is much easier.
Problem with zeroGradient wall BC for temperature - Total temperature loss cboss OpenFOAM 12 October 1, 2018 07:36
Temperature dependent thermal property in CFX Subhadeep CFX 5 March 22, 2012 02:52
air properties - heat expansion? phsieh2005 Main CFD Forum 1 November 25, 2007 10:17
Kinetic air props model - conductivity HALF? Chris Bailey FLUENT 1 March 7, 2006 11:38
AIR molecular properties Julie Polyakh Siemens 3 January 5, 2002 17:25
