#21 |
Rep Power: 144 ![]() ![]() ![]() ![]() |
Turn off the solvers using expert parameters:
* In CFX-Pre go Insert/solver/expert parameters, * Then go to "Model over-rides". Turn all the equations you are using off. That is probably fluids, but could also be energy and volfrc - possibly some others depending on what you have activated. No need for animations. In fact an animation would just confuse things. Start with the time step before it crashes. The problem region should be obvious, but in some cases you need to look closely or even use the coordinates the solver tells you to find it. |
help needed |
Having trouble with the modelling of Fluid flow during laser welding! | nadeemxs | FLUENT | 2 | August 4, 2017 10:01 |
A help needed in a scramjet combustion modelling in FLUENT | omar.2002bh | FLUENT | 0 | March 1, 2010 10:27 |
Urban wind flow modelling - formular needed | charltonjames | Main CFD Forum | 0 | September 4, 2009 08:16 |
Advice on multi-phase flow modelling | Martin | Main CFD Forum | 3 | October 14, 2008 05:16 |
turbulent modelling.... help needed | Subhodeep | FLUENT | 1 | June 24, 2006 23:41 |
