August 18, 2010, 06:19 |
Model Crude oil
Emanuele
Rep Power: 16 |
Hi, I need to model crude oil, do you have any hint?
I found liquid benzene in the library but it is not nearly viscous enough. Ideally a 32 API or 48 API oil model would be great. Ranges: Viscosity: 1.6-8 mPa s Density: about 850 kg/m3 No reactivity or combustion needed, just basic liquid. I tried to enter a model manually but I keep getting errors. Thanks for your help! cheers Emanuele |
August 18, 2010, 07:49 |
Rep Power: 144 |
If you know the properties then just stick them in. If you do it properly there should be no errors, have a look at how they do it in some tutorial examples.
August 24, 2010, 20:54 |
Joshua Counsil
Rep Power: 18 |
Several of the tutorials in the Help file and on the ANSYS portal tell you how to create a fluid.
What errors are you getting, specifically? |
August 25, 2010, 04:42 |
fixed
Emanuele
Rep Power: 16 |
Hi, I fixed it a while ago by making sure the heat transfer module and all fancy features were disabled.
I posted this thread in case somebody had a rather complete model for oil including all the features, i.e. not only the viscosity. thanks anyway for the answers! cheers Emanuele |
multiphaseInterFoam for RAS turbulence model | chiven | OpenFOAM Bugs | 8 | December 6, 2017 03:08 |
Oil combustion problem | brajh11 | CFX | 1 | December 7, 2012 02:49 |
2 stage axial turbine model convergence issues | sherifkadry | CFX | 2 | September 7, 2009 21:51 |
multi fluid mixture model issue | rystokes | CFX | 3 | August 9, 2009 20:13 |
LES and combustion model | Margherita Cadorin | CFX | 0 | October 29, 2008 06:24 |
