Lift and Drag Monitor Point Values Converging to Zero
Old   November 23, 2010, 20:01
Joshua Counsil
Josh is on a distinguished road
It's been months since I posted this, but I still suffer from the same problems. My friction and pressure graphs match the published data very well, yet the function calculator in CFX incorrectly predicts the lift and drag. Notably, it often predicts a negative drag value, whether using the "force" or "forceNorm" functions.
I reported this possible bug to ANSYS in August and never received a response. It's irritating because I have to manually perform my lift and drag calculations, plus my lift and drag history plots aren't accurate in magnitude.
Does anyone else suffer from this problem? Has it been fixed in v13?
Josh is offline   Reply With Quote
Old   May 5, 2011, 22:36
iswadi
icemaniac178 is on a distinguished road
dear josh,
i have gone through your post and i believe i have the same problem where my lift and drag value are too low and not reasonable. i also suspect there is some problem with the `force` function in the CFX calculator. is there any adjustment that u make in the CFX calculation? how do you apply the proper calculation in your works?
icemaniac178 is offline   Reply With Quote
Old   May 6, 2011, 16:07
Joshua Counsil
I was changing my inlet velocity angle to simulate angles of attack. That caused problems. I used the following thread to solve my problem:
http://www.cfd-online.com/Forums/mai...oefficent.html
Old   May 9, 2011, 01:18
iswadi
thank you mr josh,
do you mean that u used this formula to simulate the AOA variation?
L=Fy cos(alpha) - Fx sin(alpha) D=Fx cos(alpha) + Fy sin(alpha)
actually i have already adopted this formula to simulate the AOA variation.
however, my lift and drag ceofficient is still very low even at high AOA (20 degrees).
i`m thinking about changing the wing mesh rotation in order to simulate the AOA variation. is it the best technique? or are there any other better ways to do it?
Old   May 9, 2011, 11:38
Joshua Counsil
That's the formula I use.
As for your problem, there are many, many possible causes. Grid resolution, turbulence model, domain size, timestepping scheme...
You'll have to try some sensitivity analyses to figure out the problem.
Good luck.
Lift and drag calculation Franny CFX 16 November 27, 2019 14:47
Lift and drag coefficient with strange values for NACA airfoil antonio_ing OpenFOAM Running, Solving & CFD 16 September 13, 2012 13:21
Correct lift but wrong pressure drag - possible? zx Main CFD Forum 4 July 28, 2007 00:38
drag and lift coefficient Noé Siemens 5 July 13, 2004 11:21
Lift and drag values of NACA0015 Marat Hoshim Main CFD Forum 2 February 9, 2001 02:48
