HOW to calculate the NPSHR of centrifugal pump |
August 2, 2010, 10:49 |
wang y
Hi every one
I have calculated NPSHR for 20 sets centrifugal pumps by using cfx 12, but the predicted results are not satisfied when compared with experimental value. I want to kown if anyone have calculated the NPSHR of centrifugal pump.how about the predicted results? and, how to setup the cfx pre for predicting NPSHR? THANK YOU very much. water pump |
August 2, 2010, 19:40 |
Rep Power: 144 |
Have you read the best practises guide for pumps? It is installed as part of the documentation. It has a lot of good hints on pump simulations.
August 2, 2010, 20:59 |
wang y
HI ghorrocks
thank you for your reply. I have read the documents about the pump, the predicted head and efficiency of centrifugal pumps are well,but the NPSHr of pumps are bad.so I want to kown the the others predicted results and set process in cfx pre. wang y |
cavitation, centrifugal pump, cfx 12, npshr, prediction |
release of the ERCOFTAC centrifugal pump - Fourth OpenFOAM Workshop | olivier | OpenFOAM | 8 | October 29, 2018 08:49 |
Centrifugal Pump and Turbulence Model | Michiel | CFX | 12 | January 25, 2010 04:20 |
using CFX to calculate NPSHR for pump | sandy | CFX | 0 | March 19, 2008 13:52 |
Torque calculation in centrifugal pump | novice | Siemens | 0 | August 11, 2004 06:47 |
stator-rotor interaction in the centrifugal pump | G.H.Lee | Main CFD Forum | 4 | May 25, 1999 08:33 |
