Setting up a turbine nozzle case
Old   July 30, 2010, 17:52
Default Setting up a turbine nozzle case
Stephen
cfdengineer is on a distinguished road
I am using CFX v12.1 to solve flow through a high pressure turbine nozzle. Since I am new to CFX I would like to know what is the best practice with respect to setting up turbine nozzle/blade flows. Since this is a nozzle it is not rotating. I am planning to use the SST for turbulence since I was told this is the best option, but should I start with 1st order or start everything with high resolution. The reason of the run is to compare to profile data. With respect to the turbulence option the nozzle is loaded with cooling holes that mix with the hot gas. I have been told that running 1st order would be sufficient and that running high resolution would be a waste of time and that the CFX profile difference between 1st order and high resolution would be minimal. Can someone answer that. If there is a best practice or tutorial from CFX that would help out a lot. Thank you.
cfdengineer is offline   Reply With Quote
Old   August 1, 2010, 07:29
Have a look at the best practises guide in the documentation for some ideas on doing good simulations. The Journal of Fluids Engineering editorial policy (http://journaltool.asme.org/Template...umAccuracy.pdf) is pretty blunt - they won't accept models done using 1st order methods. If JFE does not accept it then should you?
Old   August 2, 2010, 06:49
Smile Setting up a turbine nozzle case
CCTech
CCTech_Pune is on a distinguished road
Even CFX help manual says we should not use the 1st Order solution as the final one.
CCTech_Pune is offline   Reply With Quote
Performance of GGI case in parallel hannes OpenFOAM Running, Solving & CFD 26 August 3, 2011 04:07
Comparison of axisymmetric case, Starccm+ and OpenFOAM linnemann OpenFOAM Running, Solving & CFD 12 June 16, 2011 06:43
icoFsiFoam case needed vivekcfd OpenFOAM 1 May 6, 2009 14:41
Transient case running with a super computer microfin FLUENT 0 March 31, 2009 12:20
Nozzle flow simulation in inviscid and viscous Cath FLUENT 0 January 28, 2007 03:16
