July 30, 2010, 11:01 |
2D Fan Analysis in CFX ...HELP Required!!
Saima
Rep Power: 16 |
Hi all,
I am working NASA rotor 67 blade. But instead of doing 3D i have started my work with 2D. When i import 2D mesh from ICEM to CFX it automatically converts in 3D by taking unit width. There are three options available for Inlet and outlet boundary conditions: 1. I put inlet: Total temp and Total Pressure Outlet: static pressure 2. I put inlet: Mass flow rate Outlet: static pressure and static temp 3. I put inlet: Total temp and Total Pressure Outlet: Mass flow rate I choose 1 with total pressure and tem at inlet and static pressure outlet. I fixed whole domain stationary and select my blade rotating with speed 16046 RPM.If i take domain rotation it doesn't run and gave error right away. I chose periodic conditions but periodicity translation because if i took rotational it doesn't run and gave error right away. As i told u CFX automatically covert 2D air foil in 3D but with small thicknes. So i took top and bottom as Hub and shroud but with symmetry boundry conditions. I tried Wall but i was not run. I choose Material :Air ideal Gas. Heat Transfer Model : Total Energy Turbulance Model: SST It runs. But result are not reasonable as i am not getting any temperature difference. T01= 288 K P01 = 101352.0 Pa I am getting T02: 288.17 K P02 = 110235.20 Pa But i havent got good result. All the time my inlet and outlet total temperature is same in all three cases. Why is that? I solved CFX and Fluent tutorial for 3D blade my conditions are almost same.Kindly suggest me what shud i do. Thank you and Regards, Last edited by Saima; August 1, 2010 at 17:16. |
Flow Analysis tilting Pad thrust bearing using CFX | julien | CFX | 5 | April 9, 2014 09:38 |
analysis 3D fan | v_h_memar | FLOW-3D | 4 | February 5, 2010 21:26 |
CFX transient analysis | mactech001 | CFX | 2 | December 6, 2009 02:11 |
Barotropic Flow Analysis CFX | Claudio2010 | CFX | 9 | October 26, 2009 18:00 |
Fan Modelling Problem in CFX | Jenny | CFX | 8 | September 11, 2007 14:59 |
