Timescale for rotating harware with long domains |
July 20, 2010, 14:48 |
Rep Power: 16 |
I am modeling an cavitating axial pump in water at 6000 rpm. The pump itself has very low blade angles and so I have included many diameters in length upstream and downstream to fully capture recirculation. The documentation suggests using a timescale approximately equal to the residence time of the fluid in the domain. For my application the residence time in the domain is ~1.2 seconds, but the residence time along the blade (which is the area of interest), is only ~0.05 seconds. I am getting an oscillation in the residuals when I try to converge the problem with cavitation. What is a good timescale to use in this case? Shouls I use a timescale equal to the total residence time or a timescale closer to the residence time in teh bladed area? Since there is recirculation at the leading edge, the residence time for some fluid is even higher since it recirculates over and over again, should I capture this in my timescale faxctor somehow? Thanks for any help. |
July 21, 2010, 00:42 |
Rep Power: 144 |
There are some tips here: http://www.cfd-online.com/Wiki/Ansys...gence_criteria
But it is always very difficult to get cavitation models to converge to a steady state, because cavitation often is not steady state but pulses. In this case increasing the physical timestep may help but you will probably be forced to look at transient simulations. Also the size of the cavitated region is often very small and the simulation well converged except at the cavitation bubble. You may have adequate convergence despite the residuals not achieving the target. |
cavitation, oscillating residuals, rotating, rotating domain, timescale |
critical error during installation of openfoam | Fabio88 | OpenFOAM Installation | 21 | June 2, 2010 04:01 |
Problems in compiling paraview in Suse 10.3 platform | chiven | OpenFOAM Installation | 3 | December 1, 2009 08:21 |
OpenFOAM-1.5-dev svn revision 1438: libOpenFOAM does not compile in SP | 4xF | OpenFOAM Bugs | 3 | October 16, 2009 06:35 |
Missing math.h header | Travis | FLUENT | 4 | January 15, 2009 12:48 |
Solid Timescale Control | Parthipan | CFX | 2 | August 24, 2007 11:07 |
