July 15, 2010, 04:34 |
Flow Reversal at the inlet
selim
Rep Power: 17 |
I have analyzed a flow field over a cylinder in pulsating flow (unsteady flow). At the inlet, we have periodic forcing with high amplitudes.
Velocity inlet: u(t)=u0+2*u0*sin(w*t); At some time the flow becomes reversal at the inlet because the time dependent amplitude is twice the steady state amplitude (u0). We have implied a velocity inlet for the inlet boundary condition. The solver gives a warning about the flow reversal. My question is about: How does the CFX solver face this problem? Thanks in advance, |
July 15, 2010, 07:47 |
Rep Power: 144 |
When you specify a velocity boundary with reverse flow does the solver construct walls to stop it? I am not sure - if it does not then you are fine and just proceed.
July 15, 2010, 08:03 |
selim
Rep Power: 17 |
Yes.
The solver gives me a warning. Something like ''A wall is constructed.....flow reversal...'' But, I am happy with my results. How can I interpret the construction of the wall? What does it mena physically? Is this not anymore a BC that I am imposing (velocity inlet)? At the outlet I a have pressure outlet BC (in this case I may also use an opening type BC) Is there any documentation of CFX about that issue? Thanks a lot, |
July 15, 2010, 11:50 |
Matthias Voß
Rep Power: 20 |
yap.
cfx is building artificial walls, since it is an "inlet" the inwards face normal has to be same like the vel.components. Try an opening with specified vel.comp. and set Expert Parameter-->Discret.-->Misc.--> build art.walls =false this should do it. neewbie |
Maintaining Static Pressure at Fluid Flow Inlet | cdevalve | FLUENT | 3 | January 14, 2012 01:11 |
Problems modeling subsonic engine air inlet with flow separation | TWaung | CFX | 2 | March 29, 2009 19:42 |
inlet mass flow rate BC | manu | FLUENT | 0 | February 5, 2008 14:24 |
velocity or mass flow inlet? | Silvia | FLUENT | 1 | August 12, 2005 14:55 |
pressure inlet in incompressible flow | dirk | FLUENT | 2 | June 22, 2005 14:27 |
