July 11, 2010, 11:44 |
odd propeller flow
anon
Rep Power: 16 |
hi all once again... i want to quickly ask what causes the flow to act like this on this fan? (assume fan is rotating with a direction inwards towards the flat plane in order to accelerate flow downstream)
Surely flow must be 'sucked in' from upstream (left) and pushed at higher velocity downstream (right) ? CFX1.png is velocity contour CFX2.png is flow streamlines with velocity variable CFX3.png is velocity vectors What am i doing wrong? Ideally if someone could briefly explain the CFX-Pre steps one should take when dealing with domain interfaces and the different types of periodicity for this problem and where once should apply them on the domains http://img191.imageshack.us/i/cfx1.png/ http://img27.imageshack.us/i/cfx2.png/ http://img138.imageshack.us/i/cfx3.png/ Last edited by s0me0ne; July 11, 2010 at 13:20. |
July 11, 2010, 19:55 |
Rep Power: 144 |
Are you sure it is not just a startup thing? That is, after running for a while longer the flow settles down as you expect.
July 12, 2010, 05:24 |
anon
Rep Power: 16 |
well i did let it run for about 30 iterations or so. (dont know if this is enough)
But it seemed that the RMS values for U,V,W-MOM all decreased and then stayed at some constant value at about 1e-4. Is this maybe too few iterations? Also, regarding the domain interfaces, i use translational periodicity a lot throughout, with a rotating domain for the fan (which the domain is like a cylinder that encloses it). Is this the correct approach? |
July 12, 2010, 07:59 |
#4 | ||
Rep Power: 144 |
July 12, 2010, 08:00 |
anon
Rep Power: 16 |
ok thank you ! , i will try doing the tutorial now
propeller flow error |
Flow meter Design | CD adapco Group Marketing | Siemens | 3 | June 21, 2011 09:33 |
Mass flow and U-Mom flow in CFX | Zhihua Xie | CFX | 0 | September 3, 2007 10:49 |
reversed flow at velocity inlet / mass flow inlet | ib | FLUENT | 1 | March 26, 2007 14:11 |
transform navier-stokes eq. to euler-eq. | pxyz | Main CFD Forum | 37 | July 7, 2006 09:42 |
Plug Flow | Franck | Main CFD Forum | 3 | September 4, 2003 06:57 |
