July 6, 2010, 07:30 |
heat transfer convergence
Rep Power: 16 |
I am performing RANS simulation on jet impingement (full 3D model) with SST tur. model. I am wondering why the heat transfer convergence is so bad, while the momentum and turbulence are good. Thx, Martin |
July 6, 2010, 07:31 |
George
Rep Power: 18 |
what are the y plus values ?
Top 4 tips 1. Knowledge is everything and Ignorance is dangerous. 2. Understand your limitations and try to eliminate them. 3. Get yerself a bike and hoon the chuffer. You will soon learn why dogs like to hang their heads out the car window. 4. Please before asking any questions on how to run simulations in CFX, go though all the tutorials |
July 6, 2010, 08:00 |
Rep Power: 16 |
y+ < 1, actually I was running similar simulation before, only for a 5 degree cut out. there the RMS convergence was comparable. in this case the momentum and turbulence RMS is <10^-5 after 500 iterations, while the heat tr. RMS ~ 5x10^-4 (1000 it.).
July 6, 2010, 19:42 |
Rep Power: 144 |
Errors in heat transfer are typically 20-40% in turbulence modelling, especially when looking at local heat transfer rates (rather than global heat transfer). It is much harder to get heat transfer right compared to momentum. This is explained in any turbulence modelling textbook.
July 7, 2010, 03:30 |
Rep Power: 16 |
thanks for reply.
Martin |
heat transfer convergence |
Convective / Conductive Heat Transfer in Hypersonic flows | enigma | Main CFD Forum | 2 | November 1, 2009 23:53 |
increasing mesh quality is leading to poor convergence | tippo | CFX | 2 | May 5, 2009 11:55 |
How can I increase Heat Transfer at Domain Interf? | B.Simon | CFX | 3 | October 28, 2008 19:53 |
Convergence in a conjugate heat transfer problem | dp | Siemens | 6 | June 9, 2006 01:53 |
Convective Heat Transfer - Heat Exchanger | Mark | CFX | 6 | November 15, 2004 16:55 |
