June 27, 2010, 13:29 |
need help for Windmill Simulation
mohamed ali
I already did the three blades windmill 3d model before, but urgently I need to study the effect of changing blade temperature on the windmill performance using CFD analysis. I did the mesh using ICEM and I started to solve it using cfx pre with multiple domains one of them solid rotating (winmill) rotates with 200 rpm and the other is stationary fluid (wind tunnel ) with inlet and outlet boundary conditions. using fluid solid interface, the solver give me error "overflow"
what is the problem. plz help |
June 28, 2010, 00:25 |
Rep Power: 144 |
Can you post the output file?
Replacing mesh while running a simulation | akultane | CFX | 1 | November 15, 2009 14:46 |
FSI TWO-WAY SIMULATION | Smagmon | CFX | 1 | March 6, 2009 14:24 |
Continuous vs interrupted simulation | sega | OpenFOAM Running, Solving & CFD | 4 | November 3, 2008 15:29 |
Fire simulation using FDS from NIST | Jens | Main CFD Forum | 1 | January 22, 2004 02:53 |
3-D Contaminant Dispersal Simulation | Apple L S Chan | Main CFD Forum | 1 | December 23, 1998 11:06 |
