June 23, 2010, 10:46 |
Radiation solid
Rep Power: 16 |
Prompt as смоделировать radiation from solid domen to fluid.
Has used the model Monte Carlo but is not seen radiations from lower to upper. Can not understand why. http://imagepost.ru/?v=161/Heat_transfer_001.png |
June 23, 2010, 19:42 |
Rep Power: 144 |
Do you need the Monte Carlo approach? Will the discrete transfer approach work for you? It is much simpler and far easier to get good results with, as long as transmittion/path effects are not significant.
June 24, 2010, 11:42 |
Rep Power: 16 |
I use the discrete transfer.
Help who knows what adsorption coefficient and scattering coefficient for hard material (clinker/cement concrete/sand). |
June 24, 2010, 19:45 |
Rep Power: 144 |
These values vary a lot. Best if you get the data for your specific material. Otherwise a google search should be able to find some representative numbers.
June 25, 2010, 07:12 |
Rep Power: 16 |
I searched on the internet, I can not find, I would know about for any solid to material are to be seen, these coefficients (in CFX uses linear coefficients with the dimension m ^ -1).
June 25, 2010, 07:36 |
Rep Power: 144 |
Well if you are looking for web values then don't expect them to be even remotely accurate. Might as well just guess. I would guess that all those materials would have a high adsorption coefficient (0.9) and a low scattering coefficient (0.1). But these values are nothing but total guesses. If you can't find real values you should do a sensitivity study on them - the exact value probably does not make any difference anyway.
June 25, 2010, 10:15 |
#7 | |
Rep Power: 16 |
CFX only requires these factors dimension m^-1. Is it possible to do something translated from a fraction of units (0,9 and 0,1) to m^-1? |
June 26, 2010, 08:40 |
Rep Power: 144 |
Oh yes, sorry - my previous post was wrong. The properties you refer to are the absorption and scattering of radiation inside the material. If you are using this solid material for particle tracking there is no radiation modelling inside the particle so these properties are not used. Just give them a value of zero.
These properties are only used for solid domains - if you have a solid domain of this material you better make something up. |
How model radiation of both solid wall and fluid£¿ | Harry Qiu | FLUENT | 2 | February 4, 2013 00:04 |
radiation transfer between solid and fluid zone | shyang | FLUENT | 0 | August 13, 2008 13:45 |
Solid to Solid Radiation | hossein | Main CFD Forum | 0 | April 17, 2008 10:32 |
CFX4.3 -build analysis form | Chie Min | CFX | 5 | July 13, 2001 00:19 |
definition difficulty-->DO radiation model | Harry Qiu | FLUENT | 0 | March 29, 2001 10:19 |
