June 22, 2010, 06:54 |
Specification of wall function, Y+ in CFX
Kishore Kumar C
Rep Power: 17 |
Hi all,
The manual defines but doesnt seem to help in defining wall function or y+. Can anybody here worked on that, please tell me where do we define/edit that in CFX Regards, Kishore |
June 22, 2010, 20:49 |
Rep Power: 144 |
It is all discussed in the documentation under wall boundary conditions.
June 22, 2010, 23:03 |
Kishore Kumar C
Rep Power: 17 |
Horrocks, Thanks for your response.
The manual doesn't say where I can specify in the user interface. If I click over the boundary which is defined as a wall, in the boundary details I can specify the wall influence on the flow or heat transfer. My objective is to switch off the wall function option to resolve boundary layers or change the y+. I am not able to find that in the user interface and the manual gives the theory and doesn't tell me where I have to do it. Kindly help! |
June 23, 2010, 09:18 |
Rep Power: 144 |
If you use k-e turbulence mode then you have to use wall functions as epsilon is undefined at the wall so you have to do something different to get that under control. If you want to integrate to the wall use a k-w turbulence model. Even better, use the SST turbulence model and it will handle the transition from wall functions to integrating to the wall by itself.
cfx 12, wall function, yplus |
[Commercial meshers] Fluent3DMeshToFoam | simvun | OpenFOAM Meshing & Mesh Conversion | 50 | January 19, 2020 16:33 |
A girl fail to plot velocity profile when mesh changes + Wall function | asherah | STAR-CCM+ | 0 | February 19, 2010 18:45 |
Compilation errors in ThirdPartymallochoard | feng_w | OpenFOAM Installation | 1 | January 25, 2009 07:59 |
3-D turbulence model with wall function | Henry | Main CFD Forum | 7 | May 19, 2006 11:40 |
Standard wall function vs Two layer model | C. ORTEGA | FLUENT | 0 | July 7, 2003 09:35 |
