Flow over a sphere, wich model should i use
Old   June 12, 2010, 23:09
Default Flow over a sphere, wich model should i use
Diego Felipe Mona´
dfmona is on a distinguished road
greetings i need some help
im confuse, i dont know wich turbulance model should i use, mi reynolds number is 12500, de diameter of the sphere is 0.065 m its enclose by a variable area duct, i have the idea that if i wanted to find accurate forces (y direction) on the sphere i should use k-e, but the resulst do not compare to the real model, you see im tryng to model a postion control of pneumatic levitation, is a steady state analysis, y got the real forces, at differnt heighs for different flow velocitys, plus im considering gravity on -y direction.
any ideas?
note: i put the gravity in the bouyancy option, 0 in x and z direction, and -9.8 in y direction is it right?
velocitys vary from 1.6m/s to 4.1m/s
dfmona is offline   Reply With Quote
Old   June 13, 2010, 11:20
Attesz's Avatar
Attesz
Attesz is an unknown quantity at this point
I think, SST k-w model is well suitable in your case. If you want to get the forces accurate, you should use a fine mesh around the sphere.
gravity settings seem to be OK, but does the gravity have significant effect?
Attesz is offline   Reply With Quote
Old   June 13, 2010, 13:39
Diego Felipe Mona´
thanx for the fast reply, refering to the model im gonna show you how is my mesh, the y+ parameter is under 3 i guess thats enough, is it? plz help me decide if the mesh is ok, remember mi only goal is to get acurate forces on y direction, its kinda like drag force. its a 3d model this is a mesh cut plane view, thanks in adanvance
http://yfrog.com/mwmeshp
Old   June 13, 2010, 17:50
Attesz's Avatar
Attesz
hi, yplus is recommended to be under two, or mostly under 1. if you can do, use yplus under 1. otherwise, you should do mesh sensitivity studies to check your mesh-dependency. if you use more finer mesh and the forces doesn not change significantly your mesh is fine enough, otherwise you should use more cells.
anyway, the mesh seems to be good enough to me.
Old   June 13, 2010, 18:32
Diego Felipe Mona´
thanx, yup i know, i have to do a mesh independence study. ok then, im gonna try moving down y+ parameter thanx alot
Use of k-epsilon and k-omega Models Jade M Main CFD Forum 40 January 27, 2023 08:18
Eul-Eul flow, k-e-kp-ep-Theta Turbulence model us FLUENT 5 April 5, 2011 03:29
Combustion Chamber flow - turbulence model folek FLUENT 0 April 13, 2010 16:58
Multiphase flow. Dispersed and free surface model Luis CFX 8 May 29, 2007 19:13
Baldwin-Lomax model in wall jet flow K.S.Chang Main CFD Forum 0 December 7, 2005 02:51
