June 10, 2010, 12:34 |
relative velocity
Rep Power: 17 |
hello,
how can i calculate the relative velocity between air (continuous) flowing over water (continuous) in CFX..i need a mean value that means a difference between the velocity in the air core flow and in the water layer because the velocity (inhomogeneous calculation) at the Void_Level=0.5 is near zero (interphase) |
June 10, 2010, 12:42 |
Rep Power: 17 |
or how can i calculate the drag force (mixture model) i need this relative velocity
June 10, 2010, 19:34 |
Rep Power: 144 |
Why do you need it? The variable slip velocity is available for post processing.
The relative velocity is already built into the drag force calculation in CFX, you don't need to calculate it again. You just call for the drag law you want. |
June 11, 2010, 03:42 |
Rep Power: 17 |
i need it for further calculation in cfx pre.. i need this velocity to calculate the most instabil wave and the wavenumber and the wavegrowth... i need it not in post
June 14, 2010, 19:26 |
Rep Power: 144 |
Have you tried to use it in the solver? You can access a lot of variable in the solver, but not all of them.
June 15, 2010, 03:34 |
Rep Power: 17 |
what do you mean with in he solver...
with two continuous phases there is no slip velocity variable? any ideaaa |
June 15, 2010, 08:01 |
Rep Power: 144 |
Most variables available in CFD-Post are also available in the solver during a simulation. I am not sure if the relative velocity variable is available in the solver so have you checked?
June 15, 2010, 08:32 |
Rep Power: 17 |
There is no variable called relative velocity in post or in pre.
That's why was my question at the beginning. Because the relative velocity is at the free surface equal to zero (theory since there is jump between the velocity profile) want to estimate or to create a velocity difference not directly at the free surface but in the vicinity (boarders of the two phase layer) |
June 15, 2010, 08:57 |
#9 |
Rep Power: 144 |
The variable Slip Velocity is available in CFD-Post, it is in the variables list. I am not sure it is in the solver though. It probably is.
In a inhomogeneous flow there will be a slip velocity between the phases so the slip velocity will exist, even at VF=0.5. |
June 15, 2010, 09:55 |
#10 |
Rep Power: 17 |
i don't find this slip velocity variable: i think this variable is only to find in case of Euler/Lagrange or continuous phase/dispersed phase
June 15, 2010, 19:23 |
#11 |
Rep Power: 144 |
OK, but as the variable you talk about is fundamental to a inhomogeneous model it will be in there somewhere, it is just a matter of finding its name. Look in the CEL reference guide in the documentation for the list of variables and hopefully you will find it.
June 16, 2010, 03:58 |
#12 |
Rep Power: 17 |
such a kind of variable doesn´t exist for Euler-Euler (with my two continuous phases ).. i hink you mean the slip velocity variable related to particles or 1 continuous+1 disperse:
Slip Velocity slipvel [ ] 1 C, M, R, TS Velocity of an algebraic slip component relative to the continuous component. i need a method to estimate this velocity Last edited by Zaktatir; June 16, 2010 at 04:47. Reason: : |
June 16, 2010, 05:57 |
#13 |
Rep Power: 17 |
can i change the variables list file ?
June 16, 2010, 09:27 |
#14 |
Rep Power: 144 |
No. But somewhere in the list will be the variable you are looking for. You just need to find it.
June 16, 2010, 09:31 |
#15 |
Rep Power: 17 |
no ...
Drag=Cd*A*rho_light phase*Urel^2 in the mixture mode this relative velocity doesn´t exist in the variable list... slip magnitude exists only in other models not in inhomogeneous two continuous phase model |
June 16, 2010, 19:36 |
#16 |
Rep Power: 144 |
Have a look in the <CFX_ROOT>/etc/VARIABLES and RULES files. I can find the following variables, not sure exactly which one you need but hopefully it is one of them:
Slip Velocity Magnitude Slip Reynolds Number Slip Velocity Drift Velocity |
June 17, 2010, 03:04 |
#17 |
Rep Power: 17 |
this variable are usable only when there is one continuous phase+dispersed phase ....
i saw already this variables in my case i have at least 2 continuous phase... thats why was asking for idea how to estimate it.... and which Urel takes then CFX to calculation for the Drag force |
June 17, 2010, 09:14 |
#18 |
Rep Power: 144 |
OK. Have you tried something like U Velocity.phase1-U Velocity.phase 2?
June 17, 2010, 10:34 |
#19 |
Rep Power: 17 |
yeah i tried that, but my Water.Velocity U Field is the same like the velocity field of Air although the calculation is inhomogeneous, and if use the superficial ones, it leads to value near zero (off course due to the volume fractions) thats why i wanted to estimte a relative velocity under the assumption that i have two constant Velocities (under and above the interface)... Onlx the cells at the interface have both entities (water and air) the other not.. and i am not sure if i can while calculating take the average value of Air.Velocity Field and the average value of Water.Velocity Field every time step and for every X location and then build the difference...
i hope u can follow it.. Last edited by Zaktatir; June 17, 2010 at 10:37. Reason: : |
June 17, 2010, 20:43 |
#20 |
Rep Power: 144 |
I don't follow what you are saying, and I don't understand why Water.Velocity U-Air.Velocity U does not give what you want.
how to derive relative velocity in MRFSimpleFoam? | renyun0511 | OpenFOAM Running, Solving & CFD | 24 | June 8, 2017 03:23 |
Problem Interface Solid Fluid with wall velocity Solver v12 | hills1 | CFX | 2 | October 12, 2009 06:36 |
relative velocity vectors | carno | FLUENT | 0 | May 9, 2008 07:59 |
Neumann pressure BC and velocity field | Antech | Main CFD Forum | 0 | April 25, 2006 03:15 |
what the result is negatif pressure at inlet | chong chee nan | FLUENT | 0 | December 29, 2001 06:13 |
