what actually is the 'zero pressure outlet b. c.'
Old   June 4, 2010, 15:09
Default what actually is the 'zero pressure outlet b. c.'
hemoGuy
hwe001 is on a distinguished road
I am simulating transient flow in a small pipe. I used transient vel as inflow B.C. and tried to use a transient pressure as outlet b. c. but the solver failed to converge.
then I set the outlet pressure to zero, the solver converged. I did another experiment, I set the outflow pressure as 80mmHg, and reference pressure as 120mmHg, again converge was difficult.
Could anyone explain what actually is the 'zero pressure outlet b. c' please?
hwe001 is offline   Reply With Quote
Old   June 5, 2010, 06:35
Umm, you define the pressure and set it to zero. Isn't that obvious?
Is your simulation compressible? Are there other inlets or outlets? Can you describe what you are modelling?
Old   June 5, 2010, 06:49
hemoGuy
it's about blood flow in a vessel of 3mm in diameter, flow velocity <1m/s.
why should I set the outflow pressure as 0, instead of 80mmHg (much more difficult to converge), which is a much more sensible choice?
Old   June 6, 2010, 07:18
You should set the outlet pressure to zero relative pressure. You should then adjust the reference pressure so you get the correct absolute pressure. Is absolute pressure important in your simulation? Is your fluid compressible or have material properties dependent on absolute pressure? If not then the pressure level does not matter.
Old   June 7, 2010, 16:22
Enio Carpi
MrFEA is on a distinguished road
Usually, similar BC's for inlet/outlet would cause convergence issues. Try using pressure at inlet and flow at outlet, or velocity/pressure, or other combination.
MrFEA is offline   Reply With Quote
boundary conditions
Pressure BC for combustion chamber Giuki FLUENT 1 July 19, 2011 12:35
Pressure Drop in outlet Vent Abdul FLUENT 2 October 28, 2008 13:13
Backflow occuring at a pressure outlet? Dave FLUENT 1 August 12, 2004 18:39
Gas pressure question Dan Moskal Main CFD Forum 0 October 24, 2002 23:02
Hydrostatic pressure in 2-phase flow modeling (long) DS & HB Main CFD Forum 0 January 8, 2000 16:00
