June 1, 2010, 09:03 |
opening temperature for the opening BC
Sujay
Rep Power: 16 |
How to define the opening temperature for opening BC as temperature is unknown at the defined location.
June 1, 2010, 19:42 |
Rep Power: 144 |
If you are doing a thermal model and don't know the inlet temperature then you can't use an opening (or inlet) boundary. You have to either specify a temperature or move the boundary to somewhere you do know the temperature, or move the boundary somewhere you can use a boundary which does not require temperature to be specified (such as a wall or symmetry).
June 2, 2010, 00:58 |
Sujay
Rep Power: 16 |
The domain has reverse flow at the outlet so needs to define as a opening. The inlet tempearure is specified at the inlet, the fluxes are assigned.
At the outlet tempearure is required output....but as it defined as a opening ask for opening or static temperature....guide to guess the temperature or any other choice. |
June 2, 2010, 02:34 |
Daniel Paukner
Rep Power: 16 |
I remember reading in one of the tutorials that it is suggested to use a CEL expression and take the average temperature of the opening
ave(T)@REGION:Outlet maybe "areaAve" would be even better. But keep in mind that this is not the best solution. A better way to do it would be to put the outlet further downstream, so that no backflow occurs. |
June 2, 2010, 04:21 |
Sujay
Rep Power: 16 |
Can you quote the reference of the tutorial where CEL is used.
June 2, 2010, 09:04 |
Daniel Paukner
Rep Power: 16 |
It's the conjugate heat transfer in a heating coil.
And they use areaAve(T)@outflow |
Problem with zeroGradient wall BC for temperature - Total temperature loss | cboss | OpenFOAM | 12 | October 1, 2018 07:36 |
Calculation of the Governing Equations | Mihail | CFX | 7 | September 7, 2014 07:27 |
monitoring point of total temperature | rogbrito | FLUENT | 0 | June 21, 2009 18:31 |
Temperature at Opening | cui | CFX | 1 | December 18, 2003 12:52 |
temperature at opening BC | Amit Katiyar | CFX | 1 | November 2, 2003 22:58 |
