May 22, 2010, 12:33 |
Additional Variable BC
Rep Power: 17 |
May 22, 2010, 13:42 |
Jordi
Rep Power: 16 |
It looks like a diffusion, is that your system? You do not provide very much info on your problem, but if it's like a heat convection, where C is temperature, then you can fix both temperature (C) and transfer coeff. (H) at the same surface, can't you?
May 23, 2010, 19:49 |
Rep Power: 144 |
Can do this with a gradient boundary with a CEL expression. Should be easy.
May 24, 2010, 16:19 |
Rep Power: 17 |
Thank you so much Glenn
Your advices have always helped me and other students. But would you please explain it more for me? or refer me to a tutorial or example? I don't know how to interpret a gradient boundary. Thanks again Last edited by Eli; May 24, 2010 at 16:47. |
May 24, 2010, 16:26 |
#5 | |
Rep Power: 17 |
C is a scaler variable and shows kind of concentration in the simulation, I just don't know how to define the Left hand of equation. |
May 24, 2010, 19:42 |
Rep Power: 144 |
Recast the equation as dC/dx=H/K(C-C0) then you have the gradient of the scalar at the boundary is a simple function. Set the function to a CEL expression and it is done.
Set this for the additional variable boundary condition at the walls. |
January 13, 2011, 09:57 |
#7 | |
Lance
Rep Power: 22 |
V*C-D*dC/dn = k*C, where V, D and k are constants and C is my additional variable. The problem is how to calculate the dC/dn as it is the gradient in the normal direction from the wall. Any suggestions? |
January 13, 2011, 17:53 |
Rep Power: 144 |
Will the CEL variables normal, with extensions like _Coordinate_Direction help you? See the CFX reference guide, "Quantitative CEL functions in CFX"
January 14, 2011, 05:56 |
#9 | |
Lance
Rep Power: 22 |
And can I define AV.Gradient X (...etc) in PRE as well? And btw, how do I define the boundary condition at the wall? The units resolve to [kg/(s m^2)]. Transfer coefficient+additional variable or Flux in? Last edited by Lance; January 14, 2011 at 12:16. |
Additional variable | John | CFX | 2 | October 16, 2008 06:33 |
Problems with additional variable | Krishna Premi | CFX | 1 | October 29, 2007 09:19 |
Additional Variable - Diffusive Transport Equation | RadheShyam Das | CFX | 3 | October 18, 2007 13:35 |
Multi_component Vs Additional Variable | Anurag | CFX | 2 | February 4, 2005 17:45 |
Replace periodic by inlet-outlet pair | lego | CFX | 3 | November 5, 2002 21:09 |
