Map Temperature Field for Structural Analysis |
Rep Power: 16 ![]() |
Hi again,
is there a way to map the temperature field from a cht analysis to a structural analysis in ansys (classic or workbench..)? Regards! |
Rep Power: 21 ![]() |
I beleive there's a beta feature in CFD-Post that will do this. Not sure of the details though, I would ask Ansys support if nobody here knows.
Daniel Paukner
just pump it through a thermal analysis
i know, its not very nice to do the same temperature solution twice, but if you apply most or even all of the surface temperatures, it will be fairly quick. Plus, i remember reading in the Ansys help, that load passing from CFX to Structural only supports pressure loads. |
transient temperature field with constant velocity | Törnquist | CFX | 0 | September 16, 2003 04:22 |
overwrite temperature field using usrsrc | jess | CFX | 0 | November 13, 2002 02:50 |
Pipe wall temperature | Fred Uckfield | Main CFD Forum | 25 | May 22, 2000 14:37 |
I wish to find the proper model to validate the temperature field. | G.H.Lee | Main CFD Forum | 1 | May 6, 1999 02:05 |
Question concering about validating Temperature field | ghlee | Main CFD Forum | 1 | December 1, 1998 12:36 |
