May 10, 2010, 18:45 |
Using pt_erosion.F
Rep Power: 16 |
Hello Friends,
I'm trying to use the pt_erosion.F supplied by Ansys in ...CFX/examples/UserFortran to customize the erosion model; however, even after loading the pt_erosion.ccl (provided by Ansys in the same directory), the solver crashes. I have compiled the pt_erosion.F with Intel Fortran 10.1 running on IA-32 and the pt_erosion.dll gets generated. So I don't really know what the problem is. It would be greatly appreciated if you can send me some insights into this. the solver error message is: ****** PROBLEM REPORT ****** | |--------------------------------------------------------------------| | Subsystem: Input | | Subroutine name: ErrAction | | Severity level: Fatal Error | | Error message number: 001100279 | |--------------------------------------------------------------------| | Message: | | | | Unable to load symbol pt_erosion from ..\winnt\pt_erosion.dll: Th- | | e specified procedure could not be found. | | | | | | | | | +================================================= ===================+ +================================================= ===================+ | ****** PROBLEM REPORT ****** | |--------------------------------------------------------------------| | Subsystem: Input | | Subroutine name: ErrAction | | Severity level: Fatal Error | | Error message number: 001100279 | |--------------------------------------------------------------------| | Message: | | | | USER ROUTINE: myerosion could not be loaded. Please check the Lib- | | rary Path, Library Name and Calling Name. For FORTRAN user routin- | | es, the Calling Name should be in lower case. | | | | | | | +================================================= ===================+ +================================================= ===================+ | ****** PROBLEM REPORT ****** | |--------------------------------------------------------------------| | Subsystem: Input | | Subroutine name: ErrAction | | Severity level: Fatal Error | | Error message number: 001100279 | |--------------------------------------------------------------------| | Message: | | | | Stopped in routine UR_REGISTER | | | | | | | | | | | +================================================= ===================+ +--------------------------------------------------------------------+ | An error has occurred in cfx5solve: | | | | The ANSYS CFX solver exited with return code 1. No results file | | has been created. |
December 19, 2013, 15:44 |
ali
Rep Power: 18 |
Hey,
were you able to resolve this issue? Thanks |
December 22, 2013, 05:48 |
uppercase
HLo
Rep Power: 13 |
the subroutine name must be LOWERCASE in ccl but UPPERCASE in fortran code. Strange, undocumented but that's fact. It is one of the issues when compiling with Mingw's gfortran, as this compiles all subroutine names to lowercase. See: http://www.cfd-online.com/Forums/cfx...nnt_amd64.html HLo |
October 7, 2014, 23:12 |
help me,please
Yang Xi
Rep Power: 13 |
hello my friend, I come up with the same trouble like you(forgive my suck English, I'm from China).I build a particle user routain and everything seems well until I run the CFX solver,then the problem report appears.Have you figured it out?or anybody who can help me!!!!Very Very appreciate
October 9, 2014, 06:52 |
Path issue?
HLo
Rep Power: 13 |
Creation of dll does not mean it is going to work. ;-(
Input files seem to be correct. Most common mistake: path to dll wrong: Where does the given "Library Path = .." really point to? Try a full path to the dll in ccl or CFX-UI first. Later try to adjust to relative path (might differ if CFX is run standalone or from workbench). If this doesn't help: Compilation with "cfx5mkext"? Architectures fit? Precision settings fit (single, double) in compilaton and solver run? |
cfx, erosion, fortran, pt_erosion, subroutine |
