May 7, 2010, 03:19 |
mass sink as a function of concentration
ranjith
Rep Power: 17 |
I am simulating flow and oxygen consumption by cells in a bioreactor. My fluid is water with oxygen dissolved in it. I am modelling the cells as a mass sink for oxygen. The problem is that the amount of mass consumed by the cells is a function of the oxygen concentration in the vicinity of the cells .When I look at CFX I can only specify constant flux rates for a boundary sink. Please advice on how I can model the sink as a function of the oxygen concentration. Would it be better if I introduce an additional variable... Ranjith |
May 7, 2010, 08:39 |
Rep Power: 144 |
Isn't it a volume mass fraction sink, not a boundary sink? I am not sure what restrictions volume sinks have but I think you will be able to make it a function of the local mass fraction. Not sure, just try it. If not then your suggestion of using an additional variable might be a good work around. What this will probably do is to make the additional variable lag the mass fraction by an iteration which may improve numeric stability.
May 8, 2010, 00:50 |
ranjith
Rep Power: 17 |
Thanks Glenn for your reply. I have infact completed the simulation. CFX does take expressions for boundary sources as a function of local mass fraction.
Thank you Ranjith |
May 8, 2010, 07:46 |
Rep Power: 144 |
I thought so. But don't you want a volumetric source, not a boundary source?
May 10, 2010, 00:26 |
ranjith
Rep Power: 17 |
True, it is a volumetric sink. But I just converted it into a boundary sink...I just took the the volume function multiplied it by the volume of the cells and then divided it by the area.... I hope that is ok...
UDS Flux Function Choice | Yang Chung | FLUENT | 1 | November 17, 2015 02:14 |
Error with Wmake | skabilan | OpenFOAM Installation | 3 | July 28, 2009 01:35 |
Can anybody help me to solve the list errors while compiling Openfoam 15 on Opensuse 103 32bit | coompressor | OpenFOAM Installation | 0 | November 12, 2008 20:53 |
mass concentration | kim | FLUENT | 0 | August 25, 2008 13:32 |
UDF ; Mass tranfer function | Jay | FLUENT | 0 | March 10, 2005 02:53 |
