Transiet Animation - vortex shedding
Old   May 4, 2010, 23:46
Default Transiet Animation - vortex shedding
Derwin Parkin
derz is on a distinguished road
Hi guys,
I'm trying to get on top of transient simulations in CFX. I've decided to try and model flow past a cylinder - I want to get CFX to show me some vortex shedding. So I'm using the same parameters as this guy used: here is his video. Inlet turbulence is 5%.
He seems to get some nice vortex shedding.
Here is my video...
I'm using the exact same parameters as him - same dimensions too. Pretty much everything he displays at the start of the video, I used. The time step is 0.025 seconds and 15 seconds in total - that's 600 timesteps. also I know I should probably be using a laminar model due to low Re, but I used k-omega because the youtube guy did too. With the laminar I don't get any shedding either...
Seeming as he is also using CFX, I can't understand why I'm not getting any vortex shedding. In fact, my animation shows no changes in the wake at all.
I ran this as a 2D simulation. However I've also tried 3D with similar results. I'm getting CFX to output results after each timestep - then when the animation is finished, I use the keyframe animation movie maker to make the movie of the changing velocity contours.
The only thing that does not match this youtube's guys simulation is the mesh - could my mesh be the reason I'm not getting any shedding? The mesh isn't very fine in the region behind the cylinder - but around the cylinder I've used some pretty fine inflation (here is an image).
Just wondering if anyone had any ideas where I'm going wrong?
Thanks,
Derwin
derz is offline   Reply With Quote
Old   May 5, 2010, 05:04
Matthias Voß
mvoss is on a distinguished road
hey,
did you even look at the resolution of th ICEM mesh?
Your mesh is way too coarse. Do some refinement in the vortex regions.
neewbie
mvoss is offline   Reply With Quote
Old   May 5, 2010, 05:55
Derwin Parkin
hi...yeah i noticed he used ICEM mesh. I have workbench ansys 12.0. i don't think i have ICEM mesh. i tried making it less coarse but still same result.
i would like to give my mesh the same type of shape as the one ICEM gives, but not sure how to in the CFX Workbench environment. It only gives me patch conforming/patch independent options.
thanks for your response...i'll focus on improving the mesh for now.
Old   May 5, 2010, 07:40
Some issues I can see...
1) Make the top and bottom walls art of the inlet boundary.
2) Your mesh is probably too coarse.
3) Your mesh is probably low quality (can tell by the jaggedness of your contours).
4) A hex mesh carefully fitted to the cylinder will help a lot.
5) And dump the turbulence model, it just damps stuff out. Run it laminar.
Old   May 5, 2010, 08:02
Derwin Parkin
Thanks ghorrocks. Yes I have started to run it in laminar. It seems my mesh is the issue - I will attempt to make it more like the meshes I've seen in many papers I've read - like this one but with a cylinder (sorry for the large picture).
Old   May 10, 2010, 10:21
Derwin Parkin
following up - i've improved my mesh a great deal. and its made a huge difference. before it took like 15 seconds until i saw a little bit of movement in the wake...now its moving noticeably after 4 secs or so. thanks for everyone's help...
K-Epsilon for Vortex Shedding Sham FLUENT 33 March 29, 2017 06:48
Vortex shedding, FSI-analysis, turbulence numerics tallknuseren CFX 3 May 10, 2010 05:31
Vortex shedding? rbel038 CFX 4 April 27, 2008 20:57
Vortex shedding behind cylider in cross flow Muthu FLUENT 0 March 6, 2006 11:29
basic vortex shedding john Main CFD Forum 4 November 6, 2000 14:23
